Will MAF issues throw EGR fault codes?
02-04-2016, 06:28 AM | #1 |
45
Rep 443
Did a scan of my 2008 320d E92 (N47) with Carly and there were plenty of faults thrown. Cleared them all and so far 4 have come back and won't clear, two of them are glow plug issues so no biggy for me at the moment, the other two are below;
004CAE - Low pressure exhaust gas recirculation actuator position sensor signal circuit or short to ground 004507 - Exhaust redirection control Now I took my EGR out a few months ago to clean it but it's not like the old M47 where you can clean all the gunk out, it was simply the diaphragm with the spindle and valve vane. Cleaned what I could off the seats and spindle but couldn't really do much more. Now I know my MAF is goosed so would these fault codes be thrown by a MAF fault? When I initially scanned my car had some faults that seemed to be MAF related but I've cleared them and they haven't returned? I've tried googling the faults but it hasn't come up with much info that is of any use? Thanks in advance for any helpful comments |
02-04-2016, 01:07 PM | #2 |
175
Rep 1,596
When the ECU opens the EGR valve it expects a drop in MAF readings, as the engines drawing some exhaust gas instead of the fresh air.
So yes, if the MAF is faulty, the ECU might get grumpy if it doesnt see what should be happening. |
02-08-2016, 08:05 AM | #4 |
175
Rep 1,596
Having said that, this fault code:
004CAE - Low pressure exhaust gas recirculation actuator position sensor signal circuit or short to ground Is a circuit fault, meaning theres an electrical issue with the EGR position sensor. Could be bad wiring or a bad sensor. I dont see how that could be related to the MAF |
02-12-2016, 02:55 AM | #5 | |
45
Rep 443
02-12-2016, 02:59 AM | #6 |
45
Rep 443
I will be replacing the MAF at the end of the month so I'll be able to see whether it makes any difference to what codes are thrown. I did a quick scan again yesterday and the '004507 - exhaust redirection control' had disappeared and a new one appeared;
00A6D1 - short to circuit positive or open circuit - additional water pump There were no issues with the car when driving however a couple days ago I got an EML for one journey but this turned off after about 10 miles? |
02-12-2016, 06:06 AM | #8 |
45
Rep 443
Ah okay that's not too much of an issue, strange how it's gone recently given I've used it a number of times in the past month, guess it hasnt been used at all throughout the cars life or something
03-31-2016, 03:44 AM | #9 |
45
Rep 443
So I can't get this fault code to clear on Carly
It's; 0040A4 - Low pressure exhaust gas recirculation actuator position, long term drift: Position deviation too high I've replaced my EGR and although it has solved one issue my car was having, the fault code is still present I replaced the vacuum line that goes from the vacuum controller to the EGR while I was there One thing I'm a little confused about, what is meant by 'low pressure EGR'? Anyone got any advice? I've done a lot of googling and can't find anything on this fault code at all? |
03-31-2016, 11:16 AM | #10 |
175
Rep 1,596
I presume this is an N47?
Theres presumably a position sensor inside the EGR valve? Realoem also suggests theres some vacuum actuator and the valve itself? |
03-31-2016, 11:19 AM | #11 | |
45
Rep 443
03-31-2016, 01:24 PM | #13 |
188
Rep 1,247
Did you replace the MAF?
If not; id search eBay using the part numbers on the MAF itself. I bought one for my N57 for £30 and the Guy had loads. Try reset the EGR adaptations in Rheingold. I had a deviation fault code as a result of cleaning my MAF which would never clear and resetting adaptations caused this. |
03-31-2016, 01:39 PM | #14 | |
45
Rep 443
I take it this Reihngold is like INPA or some software package? I would have no idea where to start if I'm honest! |
03-31-2016, 04:30 PM | #15 | ||
188
Rep 1,247
So it's just clearing the fault code? I'd try get this sorted ASAP as I left my MAF issue for 2,000 miles and I then got a 480a DPF partially blocked error. This was all due to a stored MAF code preventing regens. Rheingold is BMW dealer software in the same vein as INPA but much more modern and much more powerful. If you have a D-CAN cable it's really easy to setup. |
03-31-2016, 05:57 PM | #16 | |||
45
Rep 443
Is Rheingold free download software from online? I do need to get this sorted really as I know my car isn't getting up to temperature properly either (got thermostat and water pump on order) which is probably holding back the regens as well |
04-01-2016, 01:16 AM | #17 | ||||
188
Rep 1,247
It is worth getting sorted ASAP. I could feel my car felt sluggish before finding the DPF fault code. I was amazed that in just over 1 month of driving; the DPF partially blocked. I dread to think how bad it could have got. It may be worth throwing in a bottle of Forte DPF cleaner to give the DPF a chance of passively regenerating. Google rutracker Rheingold 3.47.10. That is a fully work version of the software. There are newer versions but they require an earlier version such as this to install. To install; Google car technology 3.44 and firstly follow the instructions on here to install. Then use the instructions in the configuration manual that came with the download to finish it off. It sounds complex but it's pretty straightforward if you follow the instructions step by step. Good luck |
04-01-2016, 01:39 AM | #18 | |||||
45
Rep 443
I'll get on to it tonight |
