Washed my car with soap and now I can see EVERYTHING...
01-16-2016, 03:31 PM | #1 |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
Hey guys, I just washed my jet black car and to my amazement, I have a ton of swirl marks. I have a grit guard and know how to wash properly but the layer of wax that I just took off was doing a good job hiding the swirl marks.
I have some ultimate compound and various pads (orange, blue, black) and a dual action. I also have ultimate finish (I think is the name) but I don't know where to start. What product should I use to get the swirls out before applying wax again? Thanks
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
01-17-2016, 01:43 AM | #2 |
602
Rep 2,703
Drives: 2009 335i - Sport PKG
OP, Zach can you help you here, ask him anything and he is very helpful Professional Detailer, he is the best
http://www.e90post.com/forums/showthread.php?t=1196641 |
01-17-2016, 02:31 AM | #3 | |
449
Rep 1,327
01-17-2016, 10:29 PM | #4 |
360
Rep 5,052
Jet black paint is a bit of a "fun" project... it tends to be relatively easy to remove defects, such as swirls and light scratches, but can require a lot of experience to produce a perfect finish when polishing.
If you have ultimate compound and ultimate polish at the ready, I would begin with an orange 5.5" lake country light cutting pad paired with ultimate compound. Assuming you are using a dual action machine like the Porter Cable 7424XP or Griot's Garage 3rd Generation machine, begin with moderate pressure and speed 4-5 (ensure you are maintaining pad rotation... if not, bump up the speed or use less pressure). Typically you will need to make 4-6 passes during this step working in a cross hatch pattern... ie up and down (1st pass), side to side (2nd pass), up and down (3rd pass), etc. Follow with ultimate polish on a white polishing pad, or black finishing pad to refine the surface. Begin with a moderate pressure for the first pass or two, then transition to a light pressure. Typically you would use a slightly slower machine speed around 3-4 (again, make sure the pad maintains rotation throughout the working cycle). 3-4 passes needed usually. Analyzing Your Test Spot by Zach McGovern Paint Correction: Pairing Products and Pads by Zach McGovern Polishing How To with Meguiar’s M105 / M205 by Todd Cooperider (<- these products are similar to UC and UP) Let me know if you have any specific questions. Always happy to help! Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
01-18-2016, 12:15 AM | #5 | |
449
Rep 1,327
