12-30-2015, 09:49 PM | #1 |
137
Rep 647
335i front brake change question
Just got a set of 335i calipers and brake pads together to upgrade on my 328i. This is my first BMW and I have no idea how to remove the brake pads. Thanks in advance.
01-01-2016, 08:12 AM | #3 |
207
Rep 603
Well, OEM calipers and brake pades of the US market 335i wont fit to the US 328i brake discs.
The OEM 335i has 340x30mm Diameter brake disc, the 328i has 312x24mm discs or 330x24mm with the M Sports package (P337A=Yes). (again on US builts with stock brakes. Europe builts 328i always have 330x24mm front disc) So before taking of the pads, make sure you have all parts that you need to upgrade to a 340x30 mm disc on front. Do you also have the 340x30mm discs, or just caliper and brake pads? If your drive currently has the 312mm disc installed, you will also need to replace the "PROTECTION PLATE" to match the disc size you want to install. F3x brake variants are not just easy... http://f30.bimmerpost.com/forums/sho...d.php?t=858607
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
01-01-2016, 04:50 PM | #4 | |
137
Rep 647
01-01-2016, 05:27 PM | #5 |
263
Rep 1,130
Drives: '16 340i AW MSport
Can you put the oem 335i front brakes in the rear? is there any problem with that?
01-02-2016, 12:45 AM | #6 |
137
Rep 647
01-02-2016, 05:26 AM | #7 | |
207
Rep 603
01-02-2016, 12:44 PM | #8 |
137
Rep 647
01-18-2016, 01:57 PM | #9 | |
453
Rep 2,973
Caliper won't fit. Rotor won't fit. Emergency brake wouldn't be functional even if the first two weren't an issue. That's just for starters.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
