changed spark plugs
12-27-2015, 08:39 AM | #1 |
28
Rep 222
changed spark plugs
Hi I recently changed the plugs and coils on my 2007 335i after the change the car drove fine for about 2 days then on cold startup it started idling real rough engine light flashes and half engine light displayed. I thought it might be my injectors called my mechanic I had purchased the spark plugs from eurocar parts the mechanic said it's probably the plugs he told me to buy new ones from dealer. If it was the plugs would it drive fine then after a day or so would it effect the idle if poor quality should I buy plugs from delaers?
12-27-2015, 09:56 AM | #3 |
28
Rep 222
He checked one-off them didn't check the rest I got them from euro car parts I would have thought they were gapped already. Any how if they were incorrectly gapped wouldn't I have noticed the bad idle as soon as I started the car after replacing plugs and coil?
12-27-2015, 10:01 AM | #4 |
Rep 78
Do you have a scan tool? If you can figure which cylinder(s) are misfiring and switch the plugs and or coilpacks and the misfire travels with it, you can narrow it down to the plug or coilpack.
2009 E90 335i M-Sport LeMans Blue
| BurgerTuning | AFE | ER | Forge | 2001.5 B5 Audi S4 Avant - Nogaro Blue - Sport Package |
12-27-2015, 11:02 AM | #6 |
393
Rep 1,371
12-28-2015, 08:01 AM | #7 |
266
Rep 952
Most likely either a bad plug or a poor connection on either coils or plugs. The process is the same, pull your plugs again and check the gaps (or replace the plugs as well). Check the connections to the coils while doing this.
bone stock
12-28-2015, 09:06 AM | #8 |
815
Rep 2,869
What plugs are you using?
Others have reported issues using non-"BMW" plugs... AKA bosch plugs... You could put your old plugs back in and test to see. If your old plugs cause no issues, then you know your new plugs are whats causing the problem.
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
12-28-2015, 09:45 AM | #9 | |
63
Rep 688
Ignore the mechanic. They love to say buy OEM to get you to call the dealer and get scared on the pricing. Then they will buy the same OEM equivalent parts from their wholesale distributor for pennies on the dollar and charge you near the BMW OEM price. Its the typical abusive relationship mind games that keep people coming back to them. I am guessing like other have said its probably a coil not seated or a failing coil pack. The plugs should come "pre-gapped". IIRC they have three prongs which would be impossible to gap anyway. One of my most vivid teen memories is doing a spark plug change in my 1986 Fiero. Legs in the trunk, leaning over the engine and cussing/swearing trying to get the plugs out of the back bank of the V6 towards the firewall. I also had to use that stupid spark plug gap tool/wheel. So unless this is Marty McFly he shouldn't be gapping these, since we aren't in the early 90's. |
12-28-2015, 12:52 PM | #10 |
266
Rep 952
As others have posted, you can't gap these plugs, but that doesn't mean you shouldn't check the gap. You can't fix one of these plugs, if the gap is wrong, but you should replace it. Just having the plug fall out of the socket and land on the electrode is enough of an impact to change the gap.
bone stock
12-28-2015, 01:15 PM | #11 | |
63
Rep 688
Normally if the gap was changed, it was a bad plug or was some type of spark plug installation error I would think the plug would be ok. I am going to lean towards a coilpack failure or came unseated. |
12-28-2015, 01:40 PM | #12 | |
1705
Rep 14,829
12-28-2015, 04:56 PM | #13 | |
432
Rep 1,602
My NGK plug all can be gapped (and needed to be gapped). |
