12-13-2015, 05:28 AM | #1 |
10
Rep 25
E-Sys flashing with "hwDeinstall" and "hwInstal"
Long story short.
I am swapping normal KOMBI with 6WB for F10 vehicle. I need to flash new 6WB with the firmware same istep as the rest of ECUs. I got red HWEL becuse this is retrofit, and the istep shipment of retrofit 6WB is not known. In order to flash, I know that I can get it done by creating SVT_soll with "HW-IDs from SVTactual" and select only blFlash, swDeploy, cdDeploy, and ibaDeploy. However, I would like to learn to take proper route with hardware replacement. Unfortunately detail information is very hard to find. If I calculate SVT with the vehicle shipment istep without "HW-IDs from SVTactual", and proceed flashing with option "hwDeinstall" and "hwInstal". Would this register the retrofit 6WB as factory original ? Which option I suppose to select ? Everything except idDelete ? I never use "hwDeinstall" and "hwInstal" before, and do not understand its exact purpose. Can anybody helps explaining ? Anybody has E-sys document which describes the meaning of hwDeinstall, hwInstal, blFlash, swDeploy, cdDeploy.... ? Last edited by cm048; 12-13-2015 at 09:00 AM.. |
