Changing plugs (N53 N54 N55) - a tip
12-11-2015, 02:54 AM | #1 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
A tip for those of you who do DIY servicing.
Been feeling my engine wasn't performing at its best for a while. But it was time to change spark plugs, so I thought all would be well. But the engine got worse! And started to misfire with a small drop in idle speed. First suspected a duff plug, but finally found that the signal lead to the injector of cylinder 6 had become disconnected. For cylinders 1 to 5, these leads are bundled with other wiring and nicely secured in place on the valve cover. But the wire for injector six is one on its own and is unsecured, from the factory. And it passes very close to the coil (which has to be removed to change the plugs). So it's easy to get knocked. So my tip is, when changing plugs, pay careful attention on cylinder 6 (the most inaccessible!) that you don't accidentally knock the injector lead off and give yourself unexpected rough running issues. Oh and with the connector fully home, the engine now runs like a dream!
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
12-11-2015, 05:59 AM | #2 |
96
Rep 828
love this type of stuff!
