325i Rocker Cover Kit
11-28-2015, 02:36 AM | #1 |
Rep 59
Does anyone know the part number for a rocker cover gasket kit for my pre lci 325i? I understand that there is a kit that includes the main gasket, bolts and seals?
Cheers |
11-28-2015, 05:54 AM | #2 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
11-28-2015, 06:04 AM | #3 |
283
Rep 2,796
Depends on what 325i engine you have you've either got an N52N or one of the early N53's. The gaskets are of course different (your chassis number will identify the engine spec) www.bmsfans.info/ is another useable parts web based system that I find is easier to use than RealOEM
But whatever one yours is don't forget to get some replacement spark plug sleeves(metal tubes in the diagram)as these can cause issues re reseating plus if reused and originally disturbed not unheard of for oil to weep by and contaminating the plug wells so well worth while changing these |
