BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 325d 2009 auto water leak rad -swapping rads
      11-26-2015, 06:45 PM   #1
thuss
Drives: e90
Hi
Just discovered a leak in my water radiator.
part number for a e90 325d auto water rad is 7794488 fits 320d to 335d..
I can get my hands on a water rad but the part number is 7788903 (according to realoem fits mainly 316d to 320xd).
both the rad Connections look the same(diameter etc).
My question is can I use the 7788903 as long as I add the control sleeve which I can take off my damaged radiator?
Thanks in advance
      11-27-2015, 06:35 AM   #2
Aragorn30d
175
Drives: E90 330d
if its for smaller engines the rad might be physically smaller/thinner?
      11-27-2015, 11:36 AM   #3
thuss
Drives: e90
physically looks the same - when you mean thinner are you talking about internal thickness of the aluminium tubes?
But looking at bmwoem the above two rads do go ontosome same model cars but the 7788903 is not listed against 325d -
I'm just concerned if the back pressure will blow the 7788903 rad.
      11-27-2015, 01:04 PM   #4
Aragorn30d
175
Drives: E90 330d
Well if you look here:
http://www.buycarparts.co.uk/oen/7788903
and here:
http://www.buycarparts.co.uk/oen/7794488
You'll notice that a lot of the aftermarket rads for those references are infact the same part number.
      11-27-2015, 05:21 PM   #5
thuss
Drives: e90
thanks for the info so basically I shoiuld be able to get away with installing the 7788903
