Gearbox oil leak 330d
11-20-2015, 05:27 AM | #1 |
Wheelbarrow Edition
60
Rep 1,608
11-20-2015, 09:48 AM | #5 |
283
Rep 2,796
Giveaway for me is the sump's plastic easily identifiable yet you showing picture of metal being contaminated.
Be careful re diagnosing where oil leaks come from on these seen a few people get them wrong in the past, sump's do leak oil, would you believe it oil filer housings can leak oil which travels along the blocks with air flow and filters down the back of the block then down and ends up coating the back of the engine on these, rocker covers etc. can also let go but as you've stated a good indy will hopefully as long as its head tech isn't Ray Charles be able to identify where the leaks from. Re trans oil trust me as it gets older goes a horrible smelly black in colour |
11-20-2015, 05:49 PM | #6 |
Wheelbarrow Edition
60
Rep 1,608
Yeah i've changed gearbox oil in the past myself and have been confronted with black horrible smelling stuff. (On previous cars)
Will have a proper diagnosis next friday. Im getting the gearbox oil changed as a matter of course as the box can be quite notchy at times. Hopefully that will restore silky smooth changes. No idea who the tech is but its a well reputable indy in Carlisle. Called auto tech i believe |
11-21-2015, 02:51 PM | #7 | |
283
Rep 2,796
Once the gear box oils all sorted and the sump's changed (don't forget the sleeve) as these leak then re set engine adaptaions and gear box as well, if there's a software update for both trust me going forward its worth looking at, but adaptaions at least will help as the 2 together can begin to adapt to new found fluid and a freeier flowing pan filter. I hope you're planning to do the pan filter and plug not just drop and change the fluid as the max benifit won't be reached Last edited by old grey steve; 11-21-2015 at 03:07 PM.. |
11-21-2015, 04:56 PM | #8 | |
DIE ANTWOORD
68
Rep 640
King of the road says you move to slow
11-22-2015, 09:32 AM | #9 |
Wheelbarrow Edition
60
Rep 1,608
Yeah its getting a new pan and filter. Or whatever it needs. Garage is doing it. Hopefully they do it correctly but they are well respected
11-22-2015, 09:53 AM | #10 |
283
Rep 2,796
My pictures posted show 3 or 4 trans sump leaks that what I was referring too. If you read one of my comments further up you'd notice that I said the giveaway for me that this wasn't a tranny leak was the fact that it was coating metal as aposed to the regal plastic tranny sump, if you read a little further you'd notice I've mentioned things like rocker cover leaks, oil filter housing leaks etc
11-27-2015, 02:33 PM | #12 |
Wheelbarrow Edition
60
Rep 1,608
Got atf fluid changed
£375 all in Best £375 i have spent. Gearbox is now silky smooth! Buzzing! Christmas Remap for myself on the way now |
