Your issues and how you diagnosed them?
11-20-2015, 05:10 AM | #1 |
Rep 94
Hey all i thought it might be good to have a thread to help others know of issues you had and how you diagnosed them.
Ill go with mine. 2007 335i N54 turbo wastegates. Symptom - loud metalic rattle on start-up and loud rattle when revs dropped to around 3k. Diagnosis - removed both vacuum pipes and revved the engine, rattle went away, replaced them and rattle came back. Camshaft bearings, vanos gears. Symptoms - half light eml, engine vibrations, long cranks. Diagnosis, EML - cam shaft position, Vanos solenoid jamming/ sticking. Radiator Symptom - leaking pink fluid from front drivers side. Diagnosis - checked colour of fluid from tissue and found crack along radiator seem. HPFP Symptoms - long cranks, engine stutter, struggle to maintain revs in warm up. Diagnosis - BMW main dealer. O2 sensor. Symptoms - Service engine light Diagnosis - Error code pre cat O2 sensor error. |
11-20-2015, 06:32 AM | #2 |
840
Rep 1,993
Drives: F30 335d
2008 320d N47
Timing chain Symptoms - noisy ticking/swishing sound. Diagnosis - BMW main dealer - fixed by them under warranty. Glow plug control unit Symptoms - fault codes Diagnosis - by myself with DIS - fitted replacement unit. DPF Symptoms - reached end of life - fault codes Diagnosis - by myself with DIS - fitted replacement unit. Aux water pump Symptoms - didn't work anymore Diagnosis - by myself with DIS - fitted replacement unit. Outer rear ball joint Symptoms - scary handling on left hand bend! Diagnosis - BMW main dealer - replaced joint at indy. Worn shock boots Symptoms - none Diagnosis - BMW main dealer - fitted Bilstein B12 by myself
if I've helped - an Appreciate would be, er, very appreciated!
11-20-2015, 06:45 AM | #3 |
133
Rep 1,381
'09 335i N54
Injectors: Very rough idle (Misfires) at cold start only with warning light, warm start was fine and no warning lights when driving. Valve Cover - Took engine cover off and inspected - found to be cracked
