BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > DCT adaptations reset
      11-18-2015, 11:05 AM   #1
AWSAWS
AWSAWS's Avatar
283
Drives: E92 GC Turbos, FBO, 335i DCT
Please,please,please,please,please! Can anyone help me figure out how to reset the DCT transmission (adaptations) using INPA?
I don't want to use the holding down the throttle method.
I get these 3 options and can't read any of them?
http://postimg.org/image/waqq2d2u5/
I have the V54 datens installed.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos)
11.74@129mph (GC Turbos)
      11-18-2015, 04:33 PM   #2
jayooo
16
Drives: E90 LCI 330d M Sport
I dont know the answer to your specific issue, however I will explain one I had recently which is very similar.
Although I had datens installed, I could not select my engine in INPA, none in the list I could read as I needed DDE 7.3 and it wasnt there. It was because I needed to add a line to the CFGDAT to tell INPA that was an available selection. Sounds like this is similar if your gearbox isnt in the list? Basically INPA wont update its lists based on the datens installed, you need to tell it they are there.
http://www.e90post.com/forums/showthread.php?t=834032
      11-18-2015, 07:52 PM   #3
AWSAWS
AWSAWS's Avatar
283
Thanks mate. Some people on other forums who have flashed their transmissions to different versions think there aren't any DCT modules and that Bav. Tech is probably the only current method.
      01-08-2016, 05:22 PM   #4
808AWD325xi
Ballin' out of control.
808AWD325xi's Avatar
No_Country
520
Drives: 2009 335i
You can reset the GS40 adaptation values with Tool32. (C:\EDIABAS\ECU\DKG_90.PRG):
Code:
	<JOB>
		<JOBNAME>STEUERN_ADAPTION_ZURUECKSETZEN</JOBNAME>
		<JOBCOMMENT></JOBCOMMENT>
		<JOBCOMMENT>Adaptionswerte Zurücksetzen</JOBCOMMENT>
		<JOBCOMMENT>( Service ID 0x30, Identifier 0x04 )</JOBCOMMENT>
		<JOBCOMMENT>Voraussetzung für ordnungsgemäße Funktion ist, dass</JOBCOMMENT>
		<JOBCOMMENT>man in Anschluss die Zündung abschaltet und den</JOBCOMMENT>
		<JOBCOMMENT>Steuergeräte-Abfall abwartet, damit die Defaultwerte</JOBCOMMENT>
		<JOBCOMMENT>im NVRAM abgespeichert werden.</JOBCOMMENT>
		<ARG>
			<ARGNAME>ADAPTIONSWERT</ARGNAME>
			<ARGTYPE>int</ARGTYPE>
			<ARGCOMMENT>Eingebe des Hexwertes</ARGCOMMENT>
			<ARGCOMMENT>0xA0 = Adaptionswerte Kisspoint K1</ARGCOMMENT>
			<ARGCOMMENT>0xA1 = Adaptionswerte Kisspoint K2</ARGCOMMENT>
			<ARGCOMMENT>0xA2 = Adaptionswerte Kupplungsmomentenkennlinie K1</ARGCOMMENT>
			<ARGCOMMENT>0xA3 = Adaptionswerte Kupplungsmomentenkennlinie K2</ARGCOMMENT>
			<ARGCOMMENT>0xB1 = Adaptionswerte für DRM</ARGCOMMENT>
			<ARGCOMMENT>0xB2 = Adaptionswerte des Semischlupfs für Gänge 1-7</ARGCOMMENT>
		</ARG>
They are wrong...
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
CarAbuser469.00
      01-12-2016, 06:15 AM   #5
AWSAWS
AWSAWS's Avatar
283
Code:
	<JOB>
		<ARG>
		</ARG>
They are wrong...
Hey thanks 808AWD325xi!
I'm at work at the moment but going to look into this tonight.
Do I load up Tool32 and find the options inside?
Pretty excited about this but I think I also want to update to the latest DCT firmware as mine is 2009 probably.
      01-12-2016, 10:32 AM   #6
808AWD325xi
No_Country
520
Drives: 2009 335i
You're welcome! In Tool32, open C:\EDIABAS\ECU\DKG_90.PRG and execute the STEUERN_ADAPTION_ZURUECKSETZEN job with the proper argument.
If you're not familiar with Tool32, be cautious and don't randomly execute jobs by pressing Enter. Use the Job menu and select Start Job once only.
      01-20-2016, 07:13 AM   #7
AWSAWS
AWSAWS's Avatar
283
Sorry for acting stupid. This resets the adaptations, correct?
What is the argument I need to provide?
Thanks
      01-20-2016, 09:42 AM   #8
808AWD325xi
No_Country
520
Drives: 2009 335i
Thanks
Yes, it does. The possible arguments were in my original post:
Code:
The specified argument (i.e. 0xa0, 0xa1, etc.) tells the job which adaptation you want to reset...clutch torque characteristic curve, semi slip, etc.
      01-26-2016, 06:08 AM   #9
AWSAWS
AWSAWS's Avatar
283
Code:
Ah I see. Thanks. Must brush up on my German.
      01-26-2016, 08:39 AM   #10
808AWD325xi
No_Country
520
Drives: 2009 335i
Code:
Google translate is your friend.
      10-14-2016, 03:29 AM   #11
yippy
Drives: BMW 335i
Hello,
is this the only way for adaption DKG with Tool32?
No way with INPA?
Thx
      10-14-2016, 06:46 AM   #12
808AWD325xi
No_Country
520
Drives: 2009 335i
You can use INPA or ISTA/D.
      10-18-2016, 04:47 AM   #13
yippy
Drives: BMW 335i
thanks
      10-21-2016, 09:50 AM   #14
AWSAWS
AWSAWS's Avatar
283
Yes ISTA is actually quite easy and runs automated tests/checking. Under servicing.
      04-27-2017, 09:57 AM   #15
juld0zer
Australia
480
Drives: Prev 135i 7DCT, Now 130i 6sp
Should this be done with the engine running and foot on the brake like how you would do it in ISTA/D?
      04-29-2017, 09:11 AM   #16
juld0zer
Australia
480
The Tool32 method just seems to default everything. I personally wouldn't do it for long term use as it may cause excessive or premature wear of the clutches. I did it, it did make the shifts a bit more firm in manual mode but there was more hesitation from a standstill and in D it seemed to hold the gears/take longer to change gears. It may learn by itself over time but who knows how long.
On my car with 144k, i didnt want to chance it so after about 100km I hooked it up to ISTA/D and went through all the resets and calibrations. Some of them must be done with the engine running, foot on brake because it engages the gears to learn the characteristics of the shift valves. For those calibrations, i dont see how clicking reset with the engine off will do it correctly. There was also no mention of a specific drive pattern to follow after resetting everything in ISTA/D. So it's pretty much a drive in drive out affair
I will post up the before and after printouts when i get back in a week. It shows the clutch actuation pressures, shift valve compensation and a few other things i dont remember at the moment.
      12-28-2017, 12:22 PM   #17
yippy
Drives: BMW 335i
juld0zer
Are there any news, pls?
I found it very interested!
With the best
Yippy
      01-05-2018, 06:23 AM   #18
juld0zer
Australia
480
Yippy, sorry for the delay. I wont be able to upload for a while as i only have internet access via my phone. Can you PM me with your email and i will send them to you there
      01-05-2018, 11:40 AM   #19
AWSAWS
AWSAWS's Avatar
283
Originally Posted by yippy View Post
juld0zer
With the best
Yippy
What is it you need to know?
As juld0zer says, you just load up ISTA/D and follow the instructions. Then it's all done. You just drive off and the transmission relearns as you drive again.
      07-13-2018, 06:03 AM   #20
roberto1988
Drives: 335i N55 DCT/DKG
hi guys
i have flashed the 135is DCT software and then I wanted to re-train the transmission but
have tried to relearn the DCT with Ista / D but I can only relearn the normal automatic not the DCT and now the car does NOT roll anymore when I go from the brake
does anyone know the problem?
thx
      07-13-2018, 09:07 AM   #21
AWSAWS
AWSAWS's Avatar
283
I can't help. Never heard of this. Can you just do the dct relearn again on ISTA/D?
It's there. I've done it myself. I also have 135is flash on the transmission. Rolls forward when idle and off the brake.
      07-13-2018, 12:19 PM   #22
roberto1988
can't because ista/d don't let me choose DKG/DCT only normal transmission
