BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      02-22-2008, 10:09 PM   #1
ChrisFastM3
ChrisFastM3's Avatar
91
Drives: E46 M3 vert w/ LOTS of mods
Wheel well gap question
Simple question,
How many inches is the gap in between the top of the fender and the tire with the optional 19's? I hope not as bad as my E46 M3..........
BTW, I ed with no luck. I hope I don't get beat up by the repost crew LOL
Chris
      02-22-2008, 10:52 PM   #2
lucid
lucid's Avatar
374
Drives: E30 M3; Expedition
The gap should be the same for the 18" and 19" wheels. I don't know how much it is though.
      02-23-2008, 01:40 AM   #3
nusevad
O! So Sour!!
nusevad's Avatar
552
Drives: Fast 240z / Slow M3
1971 Datsun 240z  [0.00]
2008 M3  [9.60]
it looks the same to me...
      02-23-2008, 10:26 AM   #4
///MML
///MML's Avatar
45
Drives: e92 M3
I've only seen picture but guessing F 2.5-3", R 1.5-2". 18"/19" should be the same gap.
2022 M240i | Brooklyn Gray | Red Leather | Black 791M rim| Black trim | HK | Premium | M Lum
      02-23-2008, 11:37 AM   #5
GregW / Oregon
Commander-In-Chief
2119
Wheel gap
Originally Posted by ChrisFastM3 View Post
Simple question,
Chris
BMWs, like most production cars, always leave enough room to mount chains at the rear. So, the gap is larger than optimum. I will be looking to lower slightly.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      02-26-2008, 10:46 PM   #6
ChrisFastM3
91
thanks for all the info guys
Anybody know the height for sure though? The reason why im asking is because I'm most likely getting aftermarket wheels & am wonderng if it's gonna need a drop (hope not, in fear of Fing w/ my EDC)
      02-26-2008, 11:52 PM   #7
///MML
///MML's Avatar
45
Drives: e92 M3
If you keep 18/19" with the stock dimensions then it will look the same. There are several close up wheel pics on the net. I don't see much reason to change the tire dimensions. On the e46 M3's the tires were too narrow and many went with wider rubber and a lower aspect ratio but this did create more gap. The e92 M3 has wider rubber.
I plan on going with 10" rears so I will go with 275/35/19 vs 265/35/19 stock. If your not going with 20" then you should be fine if you like stock look. Personnaly I hate the stock gap so no EDC for me. I will put coilovers on with about 1" drop for better stance. If you ordered EDC your pretty much stuck with the gap (new springs are not an option, IMHO).
      03-01-2008, 12:19 PM   #8
Pyrat 2
Pyrat 2's Avatar
1418
Drives: Rapidly from A to B
Here are a couple close-ups. Hope they help with your question.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      03-01-2008, 12:41 PM   #9
GregW / Oregon
Commander-In-Chief
2119
Many with the E46 went from 225 fronts to 245, and 255 to 275 in the rear. Going 20mm wider and .05 lower in aspect ratio results in virtually the same OD, so gap is not increased.
Stock rears are 265/40, not 35. But, 275/35 is probably the way to go.
I agree that the stock stance and gap is not good. I think there will be aftermarket springs for the EDC shocks that will work fine, at least I hope so!
      03-01-2008, 08:02 PM   #10
///MML
///MML's Avatar
45
Drives: e92 M3
Hi Greg,
1) May need to clarify, although the rr is nearly unchanged the gap will look larger, it's more of an illusion. Trust me, when I changed my e46 to wider rubber with same rr as stock the gap looked larger.
2) 19" stock rears are 265/35
3) Good luck with springs but I think it might cost you a few bucks over the long hall for new EDC suspension components. Springs may do Ok for garage queen cars but not daily drivers. The physics will catch up with you eventually. Time will tell I guess....
      03-01-2008, 08:20 PM   #11
GregW / Oregon
Commander-In-Chief
2119
Hi Greg,
I agree with this. Lower profile tires demand lowering the car to look right.
You are correct.
Worst case, I'll be removing the EDC suspension and putting in coilovers. At least I'd have relatively new suspension to put back in for resale.
      03-08-2008, 07:33 PM   #12
///MML
///MML's Avatar
45
Drives: e92 M3
Ok, I saw the car yesterday an measured the wheel gap so can be a little more accurate. F 2.25", R 1.25"
      03-08-2008, 10:53 PM   #13
GregW / Oregon
Commander-In-Chief
2119
Ride height
Typically, the way you measure ride height to be more accurate is:
1) Measure from fender lip to bottom of wheel.
2) Subtract 1/2 of wheel diameter.
3) Result is "ride height" from axle center. Typically rear dimension is smaller.
The reasons for this is its hard to measure accdurately to the top of the tire, and secondly, it take the tire diameter out of the equation.
      03-09-2008, 11:23 AM   #14
///MML
///MML's Avatar
45
Drives: e92 M3
Your are correct greg. I used the finger width method so I guess the word accurate is a little relative but I can say it beats the picture guess. Car had 19"s BTW.
m3post
