11-10-2015, 02:45 AM | #1 |
33
Rep 86
Michelin PSS
What pressures you all running? Mine are 36 psi according to the TPM. Have not calibrated or changed pressures since receiving. Will pump up to 39 am thinking.
11-10-2015, 03:36 AM | #2 |
143
Rep 320
Hi,
I run 32 cold (ie checked first thing in the morning before being driven), which warms up to around 34-36 warm. This is what is recommended on the tyre placard (2.2bar for two passengers, which is 31.9psi). My car came from the dealer with 40psi cold, and the handling and traction was noticeably worse. I actually find that this car / tyre combination is very sensitive to pressure, particularily for rear wheel traction under heavy throttle. I found a lot more DSC intervention / wheelspin at the higher pressures |
11-10-2015, 07:12 AM | #3 |
33
Rep 86
Interesting, was told that I'll increase wear by running at 39 or even 41 but good to know your thoughts. I looked at the placard but did not understand our take the time to interpret bars into psi. Will try running at various pressures including 32 cold to see the difference. Cheers
Edit: meant to say decrease wear by increasing to 39 or 41 Last edited by simpelton; 11-10-2015 at 07:01 PM.. |
11-10-2015, 07:00 PM | #4 |
61
Rep 377
why not just run the stock pressures?
only reason for playing with that would be if youre tracking or dragging i thought? but it will affect wear. on a side note, to the F80 come with TPMS? like actual pressure sensors in the wheels? or like our E90s just have the Flat tyre monitor that measures rolling speed of the wheels to guess a tyre is flat? |
11-10-2015, 07:09 PM | #5 | |
808
Rep 5,530
If it's not optioned, then it will run off ABS like the E9X platform |
11-10-2015, 07:11 PM | #6 |
33
Rep 86
The F80 had it as an option. I.e. pressure sensors in the wheels. F80 LCI - its standard.
No reason not to run recommended pressures. My pressures out of show room were 36. Seems 32 is the recommended (based on carriage of two passengers). Was looking for observations by those running different pressures on tyre wear and car dynamics. |
11-11-2015, 01:29 AM | #8 | |
143
Rep 320
11-11-2015, 06:11 AM | #10 | |
33
Rep 86
Running >38 will reduce wear and reduce contact and thus dynamics? I have a friend that runs 41 because he likes riding with a "stiffer side wall" (275 section but different tyre). Makes no sense to me, side walls stiffness would be based on manufacturing design and process and to my mind, higher pressures or stiffer side walls (regardless of any correlation) would cause the car to skip over undulations in the road?!?!?! Perhaps no difference on track until the tyres are well over |
11-26-2015, 11:24 PM | #12 |
53
Rep 379
32 is purely for comfort.
36-38 for spirited driving.
Current drives:2015 M3, 2014 428i, 2014 200 series Sahara Landcruiser
11-27-2015, 02:49 AM | #13 |
143
Rep 320
If your idea of spirited driving is losing traction and hanging the tail out.
Way more grip at 32 cold (around 35-36 hot on the street). I've tested at the track with pyrometers as well, 35 hot is where it is at for lap times. On the track that means starting somewhere from 24-30 cold depending on how hard you drive. |
02-10-2016, 06:34 PM | #15 |
277
Rep 579
If your going to do any sort of hard driving and you do actually push the car, >38 cold and you will be up into the high 40s. Great for reducing sidewall scrub which looks horrible but not so good for the middle of your tyre (increased wear)
02-10-2016, 10:30 PM | #16 | |
458
Rep 4,822
TPMS used to be an option but now it's standard. |
02-10-2016, 10:41 PM | #17 | |
53
Rep 379
Would 32 still apply?
02-10-2016, 11:02 PM | #18 | |
1700
Rep 2,125
3.) Curb jumping...
2016 F80 | MG/SO | DCT | Adaptive M Suspension | 19" Black 437M Wheels | CF Roof | CF Trim
