Oil changes
11-04-2015, 11:44 AM | #1 |
283
Rep 2,343
Oil changes
Hi,
a simple question to anyone who does their own oil changes. Do you have a special tool to remove the oil filter cap or can it be unlocked and put back by hand? Oh also, do you tighten the oil nut by hand or actually torque it to spec? The gap to get a torque wrench in there looks pretty small. Thanks
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
11-04-2015, 12:40 PM | #3 |
175
Rep 1,596
On the derv you cant undo it by hand, it requires a large socket. Seems the older petrols were the same, but they've changed it on newer ones.
http://cdn.bmwblog.com/wp-content/up...er-housing.png No idea why BMW has had a complete brainfart and removed the socket bit from the newer N series engines. You can get a tool on ebay: http://www.ebay.co.uk/itm/Genuine-BM...kAAOxyNo9SpzF3 What do you mean by "oil nut"? |
11-04-2015, 12:42 PM | #4 |
175
Rep 1,596
Cheaper non-oem ones also available:
http://www.ebay.co.uk/itm/Laser-3119...3D161765612466 Apollo: 36mm for the diesels, but not the newer petrols! |
11-04-2015, 12:48 PM | #5 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
You can remove the cap with a strap wrench. Mark the position of the cap before removal, then you can tighten it up to the mark without the use of a torque wrench.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
11-04-2015, 01:00 PM | #6 | |
30
Rep 210
11-05-2015, 04:39 AM | #7 | |
283
Rep 2,343
http://www.ebay.co.uk/itm/like/14136...s=true&ff13=80 Pricing things up though that 'national' oil change option looks good. £61 for the oil change and the filter and the labor. Plus you always seem to be able to get 10% off with their vouchers.
11-05-2015, 04:54 AM | #8 |
Rep 29
Be carueful with National tyres doing your engine oil service, they have been known not to even change the oil. This was proven on another forum I used to be on.
http://www.ttforum.co.uk/forum/viewt...p?f=2&t=973530 |
11-09-2015, 06:51 AM | #9 | |
283
Rep 2,343
I've seen similar reports of other companies pulling the same trick in the US. I was hoping I'd be sat near by to observe. Cowboys everywhere. If you want a job done right I suppose...
