2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Passenger side tail light malfunction
      10-31-2015, 07:19 AM   #1
M235iMMD
Drives: 2014 M235I
Hey guys,
So last night I got in my car and got all sorts of codes for the rear tail light. The turn signal, reverse light, brake light, and two stage light all have malfunction codes. The only light that does work is the running light on that side. I plan to go to the dealership next week but I'm curious if anyone else has ran into this issue or has any ideas on what it might be.
I was hoping it was just a one time fluke thing but after multiple shut downs and restarts it's still the same issue. I even tried it the next day and same problem.
It's a 2014 m235 with 18k on it. Car is stock.
Thanks everyone
      10-31-2015, 09:40 PM   #2
zipphreak
No_Country
454
Drives: m235xi
I had the bottom error and it was a faulty circuit board on the tail light. they ended up replacing the right rear tail light assembly.
      08-26-2016, 11:59 AM   #3
abdiel
26
Drives: 2016 M235i xDrive
Just had the same errors but for the left rear lights a few times these past two weeks. The errors cleared after a day the first time it happened but now is pretty much constant.
      08-27-2016, 06:47 AM   #4
zipphreak
No_Country
454
Drives: m235xi
take it to the dealer.. its a known issue with lens cracking and water leaking into the assembly causing it to malfunction randomly.. they replaced the entire right rear assembly for free.
      09-08-2016, 03:18 PM   #5
abdiel
26
Turned out to be ground wire short.
      11-17-2016, 09:23 AM   #6
P2
P2's Avatar
53
Drives: 2023 i4 M-Sport eDrive 40
I have no warning and the right rear blinker is not functioning. The dealer is replacing the the whole assembly. Part on order. Odd there's no warning.
      01-25-2017, 10:36 AM   #7
P2
P2's Avatar
53
The new part did not work. I left the dealer with no resolution. I reseated all associated fuses and it's been working for 2 months.
      12-03-2017, 12:42 PM   #8
gtmax500
77
Drives: 2016 MW M235xi
2016 BMW M235xi  [0.00]
Got these same codes intermittently last week then consistently this week. Took it into the dealer and turned out to be ground wire short as well (no lense cracking).
They overnighted a retro fit kit to replace both sides wiring harness since they said the driver side would be going soon as well. All is working now.
      12-06-2017, 10:14 PM   #9
Supernaut
Little Deuce Coupe
Supernaut's Avatar
391
Drives: SO M2C
I had the same issue last month on the driver's side - an intermittent warning for a day, then constant. It was the ground wire short as well, but my dealer only replaced the bad side. I guess I wait for the other shoe to drop.
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD
2020 Sunset Orange M2C|6MT|Black 788s
      05-14-2018, 07:20 AM   #10
omega145
omega145's Avatar
88
Drives: 2016 M235 Xdrive
Had the same thing happen to my drivers side lights on my 16' M235 xDrive. Dealer took the following action under warranty:
Replace left bulb socket - 63-21-7-370-291
Repair left tail cable - 61-12-2-448-168
Replaced bulb housing and installed updated ground cable repair kit.
So far, so good.
      05-16-2018, 07:38 AM   #11
IndyRed128i
IndyRed128i's Avatar
222
Drives: 2022 BMW 230I(Red)
http://www.2addicts.com/forums/showt...light+warranty
Had those exact same codes on mine, only the drivers side instead. Ended up being the ground wire.
      05-21-2018, 12:19 PM   #12
gtmax500
77
Got a consistent new code the past few days except this time it's "right turn signal malfunction" which I assume is the front turn signal. Anyone have problems with the front yet? I'm trying to avoid going to the dealer just yet since I still have all my mods installed.
      06-04-2018, 11:46 AM   #13
SmellyGreek
SmellyGreek's Avatar
25
Drives: Estoril Blue F22 M235i
Same issue, the SIB # is 63-05-17 (also listed in the thread linked above). Only word of caution is that the SIB says to retrofit both sides even if only one side is out -- my dealer didn't know this until they applied to BMWNA for reimbursement. It cost me an extra 2 days without my car (had to order parts for driver side, wait a day for them to arrive and complete installation), but it was all covered under warranty.
      12-12-2018, 03:15 PM   #14
P2
P2's Avatar
53
I just had the same thing on the passenger side. All lights malfunctioned. The ground pin was burnt and the ground plug on the harness melted. They did a repair with a taillight ground cable retrofit. They charged BMW 180USD. I asked what causes this. No answer. I asked if the problem is widespread. No answer.
      02-11-2019, 03:18 PM   #15
Kieu-Anh
Drives: 2015 F22 228i
Same issue here, even after replacing tail light assemblies.
Thanks for the perspective.
Had major water intrusion in right side tail light assembly on my 2015 228i and minor condensation on the left, plus the "right two-stage tail lamp malfunction" warning.
BMW tried to charge me $1,000 to have both light assemblies replaced, despite my BMW CPO warranty (driven less than 5k miles since purchase nine months ago). I asked for Warranty Goodwill service and they covered 85%, and retrofitted additional ground cables to both lights and an add'l grounding strap.
A week later, even more warning lights: right two-stage brake lamp malfunction, right rear turn signal malfunction, reverse lamp malfunction, right brake lamp malfunction.
Taking it back in next week.
      02-21-2019, 03:07 AM   #16
Clear_Blue22
Clear_Blue22's Avatar
124
Drives: 2018 230i MSport
2018 BMW 230i  [0.00]
Searched for this issue as I am also experiencing an intermittent fault of the right rear turn signal. It first happened after disconnecting the battery months ago for a Dinan elite tune install. It happened until I turned the car off and back on and went away for weeks. Over the months its becoming more and more frequent, but it would always sort itself out and work again. The really odd thing was if I turned on the hazards the light would work just fine.
It was good for about a month or so and a few days ago it acted up again. Its been days now and it's still faulted and the light doesn't work with the hazards on anymore either. It's on but extremely dim. BMW told me to just replace the bulb, since my nearest dealer is 2 hours away.... What grounding cable is faulty? Is it something that I can just tighten?
      02-21-2019, 11:23 AM   #17
714_2er
714_2er's Avatar
108
Drives: 2015 AW M235i
My 2015 is currently at dealership with moisture build up in both tail lights and left everything malfunction lol, willing to bet cracked lens and full replacement on both.
      03-02-2019, 05:35 PM   #18
Climate Changer
Climate Changer's Avatar
109
Drives: 2018 230i xdrive convertible
2018 230i xdrive co ...  [0.00]
2019 x3  [0.00]
My previous 2015 228 had all those multiple codes come on random a few times. They replaced the whole taillight. That happened about a year into the lease. Never had any other problems with the car.
Let’s hope there will be a 2021 2 series convertible
      04-03-2019, 01:00 PM   #19
msiladin
Drives: BMW m235i
Insufficient ground wiring
I just suffered the same tail light error issue on my 2016 m235i. Similarly to others I first saw intermediate and then pretty much consistent errors related to the passenger side tail light. At first the dealer thought the there was an issue with the battery - because they saw voltage related battery errors. So they replaced the battery and pronounced it fixed. However, the tail light errors appeared again. The dealer gave me a loaner and looked at it again. They called me and explained that the ground cable had oxidized (burned, not related to moisture). They indicated that the new housing now had 2 instead of only 1 ground wire.
They did not replace the driver side tail light. They said they would do so if it failed. The repair was covered under warranty (I only have 26k on it)
      04-05-2019, 01:22 PM   #20
MarcoZandrini
444
Drives: 2018 M240i
The typical cause of a burned ground wire is excessive current has run through the wire at many times.
      06-11-2019, 03:24 PM   #21
Jacob657
Jacob657's Avatar
66
Drives: 2018 BMW 230i Sport Line
2018 BMW 230i  [8.50]
2018 230i Rear Turn Signal Malfunction
I had the rear turn signal malfunction happen multiple times, randomly. Ended up bringing it to the dealer and they replaced it under warranty for free. Blamed it on moisture getting in the tail lamp and shorting a wire.
      06-11-2019, 09:17 PM   #22
Clear_Blue22
124
Mines in right now for the same thing. I let it go for several months until it was due for service. Hope it finally gets resolved. It's really annoying to hear the gong go off every time it fails randomly when I go to use it exiting the neighborhood. Some times it will fail every drive. Then it would go for weeks working perfectly fine...
2addicts
