2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions M-Performance Interior Installation DIY?!
      10-30-2015, 06:53 PM   #1
Thaimyshoee
Drives: Toyota 4Runner 16'
Question M-Performance Interior Installation DIY?!
I have M-Performance Shift knob, e-brake, carbon fiber interior pieces and alcantra steering wheel I want to install myself. I remember seeing a thread, but I can't find it anymore. Can someone help me out, thank you.
      10-30-2015, 08:45 PM   #2
nike001
312
Drives: 2018 718 Cayman
Just yank up on the knob.. it'll come off with the boot. The e-brake boot unclips from the center console trim piece and the interior pieces should pry off. Your wheel will probably give you the biggest 'fuss' per-se
      10-30-2015, 11:11 PM   #3
Thaimyshoee
Thanks nike001. The knob and boot removal seems really sketchy from a company like BMW, but I'll give it a try, thank you. I'll probably pay a shop to install the steering wheel so I don't mess anything up especially dealing with the air bags.
      11-02-2015, 10:07 AM   #4
Hemisedan
19
Drives: Coming in March: 2016 BMW M235
Well, how did the removal go? Was it as easy as it sounds? Just curious.
      11-02-2015, 08:44 PM   #5
Thaimyshoee
Hey Hemisedan, I haven't had a chance to do it yet. I'm currently deployed and I'll finally be back in a few days to put my hands on my new parts. I'll post pictures in a week.
      11-03-2015, 12:03 PM   #6
EternalVendetta
62
Drives: '16 M235i 6MT / '19 Model 3 SR
DIY master list:
http://www.2addicts.com/forums/showthread.php?t=975897
Here's a DIY for the steering wheel (I quickly glossed over the master list and didn't see a DIY for the wheel, but maybe I missed it):
http://www.2addicts.com/forums/showthread.php?t=973903
From your list, I've done the shift knob and e-brake this past Saturday, and those were among the easier installs that I did (also did M Perf pedals and kidney grilles, and a non-OEM rear diffuser, mirror caps, and rear spoiler over the weekend).
Just take your time releasing the clips on both items and be careful when yanking off the shift knob; it takes quite a bit of force to get it off, and I've heard that people have taken blows to the head when doing so. Getting the clips started on the e-brake was slightly harder than the shift knob; you may find it easier to use a plastic trim tool to get it started.
2016 M235i | Estoril Blue | Coral Red | 6MT
Tech | Cold Weather | Driver Assistance | HK
M Perf. Gear Shift Knob, Parking Brake, Pedals, Carbon Interior
M Perf. Black Grilles | CF Mirror Caps, Rear Spoiler, Rear Diffuser | Lightweight Front Lip Spoiler | M Perf. Exhaust
      11-10-2015, 09:36 AM   #7
Thaimyshoee
Thank you so much!!! It helped a lot. I'm considering installing the steering wheel myself now. So far I installed the shift knob and e-brake and it was sooo easy!
      12-31-2015, 09:45 AM   #8
minestro
Drives: BMW X2
Does anyone know how to install the M PERFORMANCE Carbon Fiber Center Console Cover? I looked at the DYI guide for the alcantara trim, but the pictures do not depict the part that I am interested in changing. Any help would be great! Thanks.
      12-31-2015, 11:02 AM   #9
ohohoh123456
ohohoh123456's Avatar
113
Drives: 2020 M4
I was looking for this as well and found something on youtube for installing this on the new 3 series, which seems to be the same setup. According to the video, you will need to remove the long trim piece to reveal the screw secures the center console piece. I'm waiting until I get the whole interior trim and then install all of them once and for all.
But I couldn't find anything regarding how to install the carbon fiber gear selector for 8AT. Anyone can chime in?
2020 M4 Heritage Edition///Velvet Blue
      12-31-2015, 06:48 PM   #10
minestro
Drives: BMW X2
Any chance you have the link to the video? I can't find it. Thanks!
      12-31-2015, 07:06 PM   #11
ohohoh123456
113
Drives: 2020 M4
Odd I don't know what i searched for to find the video, it could perhaps be a post I found on google...I don't recall really..
      01-03-2016, 07:43 PM   #12
SDKevin
Cone Killer
85
Drives: 2024 M240i, Ducati 1299S
You have to remove the plastic piece from the center first (fishing line, floss), there is a screw under there, remove screw, comes apart easy
      01-03-2016, 08:46 PM   #13
ohohoh123456
113
Drives: 2020 M4
oh that's painful sound like. how exactly do i do it then? Do i need to heat it to remove it?
      01-04-2016, 09:08 AM   #14
ohohoh123456
113
Drives: 2020 M4
Found it. It was for a M3, but I think it works the same way.
http://f80.bimmerpost.com/forums/sho....php?t=1070897
      01-05-2016, 09:35 AM   #15
tinyTIM
tinyTIM's Avatar
33
Drives: 2016 m235 xdrive
2016 BMW M235xi  [0.00]
You do not need to remove the long trim piece with the iDrive controller to replace the surround piece at the base of the shifter. Just use a pry tool and pry up along the edge. It will pop right out and then just snap the new surround right in.
Also, for the 8AT shifter itself, there is a thread somewhere I read when I did mine, I will see if I can find it. You just need to pry off the plastic piece with the Park, Reverse, Drive, M/S indicators on it. It is held on by adhesive, but you can just pry it up and pull it off. Then there is a Torx (T8 I think?) screw you need to remove. Just be sure to re-use the white plastic piece from the old assembly on your new shifter trim.
      01-05-2016, 10:06 AM   #16
tinyTIM
tinyTIM's Avatar
33
8AT Shifter
Here is the install for the 8AT M Performance carbon fiber shifter:
http://f30.bimmerpost.com/forums/sho...carbon+shifter
      01-05-2016, 10:12 AM   #17
ohohoh123456
113
Drives: 2020 M4
Thanks! Already bookmarked.
Tags
e-brake, m-performance, shift knob, steering wheel
2addicts
