Brake judder
10-29-2015, 04:34 AM | #1 |
36
Rep 242
Brake judder
I'm getting brake judder through the steering when I apply the brakes, it gets worse the harsher the braking. I'm pretty sure it's a warped disc, looking at the near side disc, it looks like something has 'gauged' the disc.
The pads look decent on both sides. Is it simply due to poor fitment of the disc? Eicher discs and pads? Last edited by chrissyw; 10-29-2015 at 05:16 AM.. |
10-29-2015, 05:16 AM | #2 |
45
Rep 441
Stones and other 'stuff' could get caught in between the disc and the pads to cause small gauges but you'd probably hear a light grinding if you ever drive with the window down
Discs are piece of p*ss to do on these, if you're compitent you could do both front discs and pads in an hour I reckon given you have all the tools needed which isn't much Took me two hours to do my front discs and pads and I was working on an awkward driveway in the dark and had never touched the brakes on the car before |
10-29-2015, 05:19 AM | #3 |
36
Rep 242
Just watched a couple of videos on youtube. It looks pretty straight forward. Does the wear sensor cable just clip off?
Do I need to apply copper grease to the hub? |
10-29-2015, 05:40 AM | #4 |
45
Rep 441
I applied copper grease yes but not a massive amount, just a very light coating to keep off enough corrosion to prevent the disc from getting stuck
And off the top of my head I can't remember how the sensor cable fixes in place, I didn't change mine as it hadn't been touched yet The pads had a lot left in them but discs were dead so changed the lot and just left the wear sensor |
10-29-2015, 05:56 AM | #5 | |
36
Rep 242
10-29-2015, 06:17 AM | #6 |
45
Rep 441
No I went with Pagid discs which I regretted straight away having read threads on here of them warping after very little use
However I've done maybe 6k on mine and they've been fine Also went with Pagid pads, so far I can't complain with their performance and they've had a few hard 'sessions' across Dartmoor and Cornwall too |
10-29-2015, 06:31 AM | #10 |
175
Rep 1,596
I've just done mine recently. I used Jurid pads and i think Febi disks from All German Parts.
Oddly i've still got a vibration, so whatever it is, wasnt caused by the brakes. I'm thinking front suspension arms or something? |
10-29-2015, 06:33 AM | #11 |
45
Rep 441
Would the 'tension arms' cause this under braking?
10-29-2015, 06:38 AM | #12 |
175
Rep 1,596
i've read that they could, yeh.
Its on 145k and probably original suspension, so not really a huge surprise. I'll get the bits lined up at some point and do the four control arms, top mounts and rod ends etc just to freshen it all up. Probably swap the dampers out for some Bilstein B4's at the same time too. |
10-29-2015, 06:40 AM | #13 | |
36
Rep 242
Mine gets worse the more weight that's in the car. Hmmm Last edited by chrissyw; 10-29-2015 at 06:56 AM.. |
10-29-2015, 06:57 AM | #14 | |
45
Rep 441
10-29-2015, 07:30 AM | #15 |
175
Rep 1,596
Yeh. My dampers are some weird "Sachs ProTouring" things, i think they've been changed, they look very new.
I will probably keep the MSport springs, might add the lowering plates for the front, rear rideheight is fine, front could drop a little bit, and the spring rates on the eibachs arent really any different anyway. Its just that i cant be arsed taking things apart multiple times, so i'll end up getting all the bits together, and doing the whole lot in one hit. |
10-29-2015, 07:34 AM | #16 |
36
Rep 242
I'm gonna go with ATE discs I think. Can't get Jurid's from Eurocarparts.
What pads are decent? Got a choice of ATE, Textar, Eicher and Pagid. |
10-29-2015, 07:56 AM | #18 |
36
Rep 242
11-02-2015, 04:07 AM | #20 |
36
Rep 242
One last question sorry, are the E90 320d M Sport discs 300mm?
I'm seeing 300mm and 312mm on eurocarparts! Last edited by chrissyw; 11-02-2015 at 04:18 AM.. |
11-02-2015, 04:33 AM | #22 |
36
Rep 242
