ISTA/D Scan - Identifying fault codes
10-28-2015, 02:53 PM | #1 |
16
Rep 74
Evening all, just done a quick ISTA/D scan, and was wondering if anyone can shed any light of a few of the codes detected on the attached pic please?
The car is in AUC warranty until Jan - I will be taking it in before then to get anything rectified. The DDE glow plug faults are self explanatory, everything from IHKA down is not. Google doesn't return much on these codes either. I have a feeling given the mileage these were triggered, I have triggered them myself inadvertently when coding 6NR, which from recollection would have been about the mileage the faults were logged (I coded VO to the whole car by mistake instead of just CIC and Media). Not too concerned as its in warranty, just curious if anything is actually wrong or I have caused these logs. I also dont want to clear any faults as if something needs replacing, the fault will need to be seen by BMW. Thanks James Last edited by jayooo; 10-28-2015 at 02:57 PM.. Reason: resize pic |
10-28-2015, 02:58 PM | #2 |
175
Rep 1,596
clear the fault and see if it returns?
If its a real issue (like the glow plugs) it'll come back. If its a old code caused by your bad coding then you wont see it agian. They're all relating to bad canbus messages from the CAS. |
10-28-2015, 03:00 PM | #3 |
16
Rep 74
Had considered clearing, however the glow plug faults have occurred more than once but are quite sporadic mileage wise.
Knowing my luck I will clear and the fault wont return until just out of warranty..... |
10-28-2015, 07:41 PM | #5 |
79
Rep 540
Don't worry about the other faults after the IHKA. They are just general information faults that occur, won't cause any symptoms. A dealer won't entertain this by the way, they can scope the line but the frequency of the fault is probably only one and it will probably scope correctly and would be to difficult to reproduce an issue that shows no symptoms.
10-29-2015, 04:36 AM | #6 |
16
Rep 74
Cheers guys, might have a fiddle with INPA and clear everything except DDE as you suggest Aragorn, should work out ok as I have never managed to get my INPA to work with DDE 7.3 for the N57 anyway - most other modules I can read fine
Glow plug 2 and 5 have a few errors as does the glow plug module, so would like these sorted under warranty. My worry was that the DPF wont regen with certain glow plug combinations out, however ISTA states my last regen was 220km ago - so if this is accurate my worries are settled |
10-29-2015, 07:36 AM | #7 | |
175
Rep 1,596
