2011 M3 - Alpine White- Swirled and marred
10-26-2015, 01:22 PM | #1 |
Rep 15
The owner of this 2011 BMW M3 contacted me in hopes of improving the appearance of his vehicle’s paint in direct sunlight. Upon inspection it was evident that the car had been polished incorrectly with a rotary buffer, leaving swirl marks over every panel, in addition to moderate to heavy marring from improper washes. Despite being white, a color which typically masks such defects, the damage was still very apparent in any sort of direct lighting (sunlight, fluorescents, etc) and caused a dull appearance even when the paint was clean and waxed.
Before: Here the car was clean and freshly waxed by the owner, but it lacked the deep, wet shine of corrected paintwork: DSC00396 by Mike Donoghue, on Flickr DSC00399 by Mike Donoghue, on Flickr The wheel barrels were in need of a detailing and would be cleaned with Optimum Power Clean (3:1) and an EZ detail brush: DSC00400 by Mike Donoghue, on Flickr Under LED lighting the damage to the paint was easily detected. In person the swirls and marring were actually much worse, it was just very difficult to get the camera to reflect this given the white paint: DSC00420 by Mike Donoghue, on Flickr DSC00422 by Mike Donoghue, on Flickr DSC00423 by Mike Donoghue, on Flickr DSC00426 by Mike Donoghue, on Flickr DSC00428 by Mike Donoghue, on Flickr DSC00430 by Mike Donoghue, on Flickr DSC00431 by Mike Donoghue, on Flickr DSC00437 by Mike Donoghue, on Flickr DSC00441 by Mike Donoghue, on Flickr DSC00453 by Mike Donoghue, on Flickr DSC00458 by Mike Donoghue, on Flickr After a thorough wash with Chemical guys Citrus Wash & Gloss, the foam cannon and filtered water (via CR Spotless), the car was clayed and then different polishing approaches were tested until a satisfactory result of ~80% correction was achieved with the Rupes 21 & 75E polishers along with Lake Country black pads and HD Polish. The paint was then topped with Optiseal and the tires were dressed with 3D Thick Dressing. After: DSC00492 by Mike Donoghue, on Flickr DSC00493 by Mike Donoghue, on Flickr DSC00496 by Mike Donoghue, on Flickr DSC00498 by Mike Donoghue, on Flickr DSC00499 by Mike Donoghue, on Flickr DSC00502 by Mike Donoghue, on Flickr DSC00504 by Mike Donoghue, on Flickr DSC00511 by Mike Donoghue, on Flickr DSC00517 by Mike Donoghue, on Flickr DSC00518 by Mike Donoghue, on Flickr DSC00523 by Mike Donoghue, on Flickr DSC00530 by Mike Donoghue, on Flickr DSC00535 by Mike Donoghue, on Flickr DSC00536 by Mike Donoghue, on Flickr DSC00541 by Mike Donoghue, on Flickr DSC00542 by Mike Donoghue, on Flickr DSC00545 by Mike Donoghue, on Flickr DSC00547 by Mike Donoghue, on Flickr DSC00549 by Mike Donoghue, on Flickr DSC00551 by Mike Donoghue, on Flickr DSC00553 by Mike Donoghue, on Flickr DSC00563 by Mike Donoghue, on Flickr DSC00610 by Mike Donoghue, on Flickr Despite the lack of complete correction, this M3 looked worlds better and both the owner and myself were happy with the outcome. Thanks for looking, comments and questions welcome!
Mike Donoghue
Pinnacle Auto Detail - Paint correction, coatings and more - serving all of CT http://www.pinnacleautodetailct.com/ |
10-27-2015, 11:46 PM | #2 |
602
Rep 2,703
Drives: 2009 335i - Sport PKG
Nice work, was it one step correction? if yes what polish/pad?
10-28-2015, 07:22 AM | #4 | |
360
Rep 5,052
The mentioned correction combo is quite light. If your paint is in below average condition, a bit of a more aggressive pad and/or polish would have yielded even better correction and likely would not have sacrificed the final finishing qualities either. In this video, I am using the Rupes LHR21ES with an Orange Lake Country Light Cutting Pad and Menzerna MC2500. You will see that even though the paint is in very poor condition, almost every single defect was removed using this still mild polishing combo. Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
10-28-2015, 12:14 PM | #5 |
Rep 15
Thanks guys!
SHEEDI- Yep, this was a one step, though the term may be misleading since I actually did two applications of HD Speed per section, each time working the product for an appropriate number of passes to get the desired correction rate.
Mike Donoghue
