F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Suggestions for DD/Autocross alignment please
Studio RSR
      10-23-2015, 07:54 PM   #1
wpgfordguy
Drives: 2014 328i
I did use the search function 😀
I have a f30 328i (base car)
H&R FSB and RSB
245-45-17 RE71 R's
Otherwise stock.
I'm new to BMW ( Autocrossed mustangs for years)
What's a good spec to give my alignment shop?
Thanks
2014 328i Base car, sleeper mode on
245/45/17 x 4 Re71 r's
Turner / Afe Scorcher
Turner / H&R Front and rear sway bars
Turner Stainless Brake lines
      10-26-2015, 01:08 PM   #2
utenigma
162
Drives: 2013 F30 335i 8SA M-Adaptive
Without additional hardware in the front, there's nothing to adjust but toe
Stock alignment has a little toe-in in the front and rear, for starters, zero out the toe in the front and rear then set the rear camber to -2 degrees
That's about all you can do with the stock hardware
      11-09-2015, 01:42 PM   #3
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
+1 on zero toe in front and more rear camber
I'm not 100% sure on the zero rear toe. I personally would like some toe in and perhaps OP could track the car with stock settings to figure out preferences before making the initial alignment change
      11-12-2015, 08:48 AM   #4
utenigma
162
It's a preference thing. Zeroing out the rear toe destabilizes the rear which helps a long car rotate around the cones.
If you want the rear to stay inside the front tires, keep the toe stock in the rear. If you want the rear to step out a bit, zero it out.
f30post
