2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Winter runflat tyre options for F10 19" rims?
      10-23-2015, 05:52 AM   #1
Rookie66
Drives: 520d M-Sport Touring
4 years with F11 17" rims with no problem fitting Dunlop Wintersport 3D runflats via Kwik-fit "tyre hotel" service. Great tyres.
New F10 (520dM) this smmer & assuming I could do the same.
Struggling to see any 19" (275/35 R & 245/40 F) run-flat winter options.
Anybody know whether such exotica exists? If not - best alternatives?
Ideally runflats & using same rims.
Thanks in advance!
      10-23-2015, 06:23 AM   #2
njc
58
Drives: G31 520d M Sport
Try Tyreleader.
      10-23-2015, 06:28 AM   #3
njc
58
It is probably a lot cheaper to buy a square set up including Tyres and Alloys on 18" - I believe taking Runflats on and off rims isn't recommended as it can damage the reinforced sidewall.
      10-26-2015, 06:01 AM   #4
morellomax
119
Drives: 2022 M440i xDrive convertible
Agreed - I wouldn't try to change tyres over on a set of 19s, and a set of 18s or 17s for winter will be better in every way - more comfortable, cheaper, less chance of rim damage from potholes, etc etc. Less risk of aquaplaning as well, where tyres are slightly narrower.
      10-27-2015, 05:27 AM   #5
Rookie66
Thanks both.
But didn't have any problems with four winter-tyre/summer-tyre changeovers on last car (albeit with 17" rims....but don't see how 19" would change that?).
Surely new wheels AND tyres would be more expensive than just tyres?
Cheers
      10-27-2015, 06:37 AM   #6
gspannu
200
Drives: F10 535, F82 M4
Originally Posted by Rookie66 View Post
Thanks both.
Cheers
You are increasing your chances of damaging the rim each time you remove/ put on tyres - thats the only risk.
      10-28-2015, 09:09 AM   #7
morellomax
119
It's much harder to remove and refit 19" tyres than 17" tyres, especially RFTs, because of the lack of play in the sidewall.
A set of 17s or 18s (rims plus winter tyres) on ebay shouldn't cost much more than a set of 19" winter tyres on its own, and you'll have something of greater value to sell on in a few years' time.
Just an example: http://www.ebay.co.uk/itm/BMW-F10-5-...-/252133921899
HTH, IMHO, RSVP etc etc !
      10-28-2015, 09:15 AM   #8
morellomax
119
Actually, scrap that advice for now. Do you have the full tyre pressure sensor system i.e. readout of actual individual pressures on screen ? If you do, then any rims for winter tyres will also need the sensors and that bumps up the price and reduces the available options on ebay.
      10-29-2015, 03:58 AM   #9
njc
58
Or if you were content to live with the warning sign on the dash for the duration of the winters being fitted then for me it would be the most cost effective way of booting your car in winters.
      10-29-2015, 05:52 PM   #10
morellomax
119
Might be an insurance and MOT fail though ?
      10-29-2015, 11:53 PM   #11
IanS100
IanS100's Avatar
England
136
Drives: 520d F10 LCI M Sport
You say you're struggling to find tyres and ask for the best alternative, but reject it, if you can't find winter tyres to fit your 19" wheels, a set up winter wheels will be your 'only' alternative.
17" or 18" wheels & tpms can be purchased for about £600 or less new, and you will make quite a saving with the cost of much cheaper tyres. Factor in a residual value for your winter setup and the overall long term cost will be negligible.
If you do manage to find 19" winter rubber they will probably be very expensive, and damage one of the wheels or tyres while being swapped over, which is very real possibility with RFT tyres, or clip a kerb in the snow etc and a cheap winter set will start looking very attractive.
Have a look at these: http://www.mrwinterwheels.co.uk/17-b...-tyres-xr.html
They also come in 18" if you prefer, I and many other forum members have gone for these, they're a good wheel at a reasonable price, look similar to OE M Sport wheels, and they have the recess for the tpms, what's not to like?
      11-10-2015, 07:01 AM   #12
Rookie66
Bit harsh saying I "rejected" advice.
I was just sharing my experience of 4 years with no problems & asking if anybody knew of a tyre that would fit?
Have found some now (thank you) & they are expensive (£450 each!) ..... non run-flats are actually more.
Just weighing up choice now between having them (company car) or leaving it.
Personal choice again - but I like the OEM look & the way the car looks with 19s.
Cheers
      11-10-2015, 08:14 AM   #13
morellomax
119
£450 each - wow...
I do agree about the looks, F10 does look just right on the MSport pack 19s or similar, but I'm not willing to go through that kind of pain to keep my looks !
      11-10-2015, 01:56 PM   #14
njc
58
Cheers
£450 ouch....I'm sure you could of got a set of OEM 18" alloys and tyres for that price.
      11-11-2015, 12:06 AM   #15
Balster
Balster's Avatar
109
Drives: BMW G30 530d MSport xDrive
I was told by a BMW indy that non RFT's are non standard parts and would invalidate the insurance. I've read similar posts (and responses) on here.
G30 530d M Sport xdrive, Adaptive Drive and with all of the important options.
      11-11-2015, 02:58 AM   #16
gspannu
200
Not really, You only need to inform your car insurer about the same. BMW does sell these cars with non-RFT tyres, so the parts are technically not non-standard.
Some insurance companies may be slightly more difficult to convince than others, but eventually they will come around. Also since these tyres being sold in the UK are EU compliant, the insurance cannot really fight it.
Some insurance companies even have an issue with 'Winter Tyres' (regardless of RFT or not). The fact that you are changing tyres seems to get these insurance companies into believing that the car has 'been modified'. Speak to the insurance company - -and usually they should come around...
      11-11-2015, 03:25 AM   #17
Rookie66
Down to £320 now & they're RFTs.
Just need to store my summer ones myself rather than use Kwik-fit's "tyre hotel"! Loft....here I come!
I'll justify (to myself!) by thinking I'd have to buy another set of summer ones anyway during the 4 year lease......so these just replace those ;-)
      11-11-2015, 04:36 AM   #18
gibbonm
Drives: BMW 535D M Sport
I am in the process of selling my original M351's in 19" with 4 good 5-6mm Dunlop RFT's if you are interested and were thinking of keeping 2 sets rather than change the tyre twice a year, i believe changing a rft can damage the tyre over time? maybe remove the tyres on my wheels, fit the Winters on them and when you have to change your summers before the lease is up you have 4 tyres ready and waiting? work out cheaper in the long run?
      11-16-2015, 09:47 AM   #19
Rookie66
Thanks for offer - but I'll stick with current plan.
PS sent last car back with winters on at end of lease ;-)
5post
