Need to remove spoiler residue from my trunk
10-22-2015, 05:35 PM | #1 |
Came to the N55 Darkside
1112
Rep 12,740
So I slowly pried off my black sapphire metallic spoiler for my E93, and was left with a messy combo of leftover plastic bits and double sided adhesive.
I'm fairly certain that if I remove it properly I can retain the paint and finish on my trunk, but I am just not sure the best way to go about it- any ideas? |
10-22-2015, 08:04 PM | #4 |
1112
Rep 12,740
Thanks guys...should've used some heat to loosen up the spoiler.
On a somewhat related note, it's on sale for 100 clams- painted black sapphire metallic- if anyone's interested, but it will only fit an E93 trunk I believe... |
10-23-2015, 03:17 PM | #5 |
59
Rep 661
Just use your fingers and peel it off. I just did this when I changed mine from a low kick to a high kick. I just used my fingers to push on the residue and it would roll/ball up and then you pick it off. It's tedious and time consuming but my paint wasn't harmed. I had just polished it and it still looked perfect afterwards.
10-23-2015, 10:53 PM | #6 |
601
Rep 2,703
Drives: 2009 335i - Sport PKG
OP, I would say, save yourself from headache and damaging the paint further, get it removed by Professional detailer. incase if you decide to see a professional detailer, I would also recommend you get the entire car mini detail if it requires one. I found this detailer http://lidetailers.com/blog.html on www.detailedimage.com
Good luck |
10-23-2015, 11:48 PM | #7 |
First Lieutenant II I know enough to be dangerous
76
Rep 465
This is what you need. 3M Stripe off wheel. I've used this to remove pinstripe and adhesive tape. Your local auto parts store might have one. I got mine at O'Reilly Auto Parts.
It works best if you heat up the adhesive a bit first with a hair dryer or heat gun. http://www.amazon.com/3M-Stripe-Whee.../dp/B00063VT0G
2010 E90 LCI N54 335xi / AR DP's / KW V1 / Stoptech Slotted Rotors / SS lines / EBC Yellowstuff / Fuel-it stage 2 LPFP / Fuel-it Bluetooth Content Analyzer / ETS FMIC / VRSF CP / TurboSmart Dual Port Kompact kit / MHD / WEDGE E60 ProTune / CORSA Exhaust / Alpina TCU / VTT Outlets / MMP Inlets
10-26-2015, 01:24 PM | #10 |
Rep 15
Clean the area, roll the large chunks off with your fingers and then use 3M specialty adhesive remover & microfiber towels to clean up what remains.
Mike Donoghue
Pinnacle Auto Detail - Paint correction, coatings and more - serving all of CT http://www.pinnacleautodetailct.com/ |
10-26-2015, 07:02 PM | #11 |
1112
Rep 12,740
Unfortunately I discovered a more detrimental problem... there are pieces of plastic with what appears to be a silicone or beta-link bond under them... looks like a job for the local body shop.
The body shop did a little too good of a job making sure that spoiler wouldn't go anywhere when I first put it on it seems, and I can't really fault him for that. |
10-31-2015, 11:02 PM | #14 |
601
Rep 2,703
OP, have you ever think of trying these?
http://www.autogeek.net/carpro-tar-x-600ml.html http://www.goofoffproducts.com/produ...r-glue-remover http://www.acehardware.com/product/i...624942.1260468 |
