DAB Radio
10-19-2015, 03:45 PM | #1 |
Rep 173
DAB Radio
Hi All,
Quick question thats bugging me, Ive just bought an E93 with pro nav etc etc well this ... BMW TELESERVICES 6AB CONTROL TELESERVICES 6FL USB-/AUDIO INTERFACE 6NF EXT.CON.OF THE MUSIC PLAY.I.MOBILPH 6VC CONTROL COMBOX 609 NAVIGATION SYSTEM PROFESSIONAL 612 BMW ASSIST 615 EXTENDED BMW ONLINE INFORMATION 616 BMW ONLINE 620 VOICE INPUT SYSTEM 633 PREP.MOB. PH. BUSINESS BLUET.INTERF. 688 HARMAN/KARDON SURROUND SOUND SYSTEM 694 PREPARATION FOR CD CHANGER 698 AREA-CODE 2 7XA M LEATH.STEERING WHEEL W.PADDLES/MULTI etc et now I was expecting this to have DAB as standard! is that an optional extra too? because I don't have it! gutted . |
10-20-2015, 01:48 AM | #4 |
136
Rep 5,050
I'm guessing you'll need to replace your Pro Nav unit with a DAB version, buy & fit the correct aerial, emulator & coding. The DAB units are fairly rare so expect a premium price, so I doubt you'll get away under £1k for an OE DAB retrofit, and depending who you get to do it, it could be a helluva lot more
10-20-2015, 07:04 AM | #5 |
456
Rep 2,749
there is geniune dab retrofit kit
http://www.realoem.com/bmw/enUS/show...diagId=65_2440 look like it's from connect2s autodab
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
10-20-2015, 07:08 AM | #6 |
337
Rep 1,660
That looks very much like the "AutoDAB" kit, easily obtainable at your local eBay page.
Otherwise, there is a "Fistune" that may be mounted in your boot and connect up to your CD changer Prep. Get an active antenna to stick on to your rear window so it doesn't look quite as messy as a front window stick-on. You control this through iDrive, so doesn't have the additional remote. Mike |
10-21-2015, 04:09 PM | #8 |
30
Rep 226
10-23-2015, 10:22 PM | #9 | |
55
Rep 366
11-01-2015, 05:22 AM | #10 | |
Rep 173
Has anyone had experience of these? |
11-02-2015, 06:34 AM | #11 |
337
Rep 1,660
If you're on Pistonheads, "Eatontrifles" did a write up and video on fitting this to his E91. He did a good description on BMWLand too, now sadly gone.
Mike |
11-02-2015, 08:08 AM | #12 |
126
Rep 2,022
Another option - I've got a DAB CIC, which you can have for £340 + your current CIC. This will include a plug n play emulator & coding.
Because you have a E93, you will need an aftermarket dab aerial. |
