Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > E91 wheel choice
      10-16-2015, 06:03 PM   #1
Nick91
Drives: E91
E91 wheel choice
Hi all new on here. Recently purchased an early 2007 e91 m sport and want to put 19 inch csl reps on and maybe coilovers later on. Could anyone give me some advice on wheel sizes and offset, and recommended tyre sizes. Don't want to be using spacers if I can help it but want the wheels to fill the arch.
Any help much appreciated.
      10-17-2015, 03:02 AM   #2
Aragorn30d
175
Drives: E90 330d
Its a tricky one because everyones idea of "filling the arch" differs.
With the standard wheels and offsets, a 12mm spacer on the rear of a pre-LCI car makes all the difference with regards to how the wheels look sunken in, but many folk would think its not enough and go further.
Theres a few websites around where you input the existing and new offset and width and it'll show you how the wheel sits compared with stock
Or you can simply calculate it out yourself. Each extra inch of width has the wheel sticking out 1/2" more and in 1/2" more.
a reduction in offset moves the wheel out by that distance
So if you start with a 8.5J rim at ET37 (stock rears) and swap to a 9.5J rim at ET30 for instance,
Your wheel will stick out 12.7mm more due to the extra width, and 7mm more due to the extra offset, giving a total change of 19.7mm outwards.
You can then compare this with your car and see what you think.
Also each car differs slighly, some folk will run a combination that works fine, others might run the same combination and it catches on bumps and needs the arches rolling.
      10-17-2015, 03:13 PM   #3
Digitalize
Photographer
Digitalize's Avatar
412
Drives: 320D
Don't do CSL, outdated design for the car, do M359s instead.
      10-17-2015, 04:29 PM   #4
R99
1099
Drives: 2016 330d F31 Touring
My E91 touring on CSL reps - 19x8.5 et38 front and 19x9.5 et33 rear.
225/35/19 tyres up front and 255/30/19 on the rear.
      10-17-2015, 04:39 PM   #5
MattOz
MattOz's Avatar
342
Drives: Alpina G21 D3S
2011 E90 M3  [0.00]
My E91 has the BMW performance 269's, which suit it nicely..
      10-18-2015, 03:25 AM   #6
Nick91
Drives: E91
Thanks for all your help. Would a 9.5 with et27 rub on the back or would I be better off with the et40
Thanks
      10-18-2015, 06:19 AM   #7
R99
1099
I think you will be OK with the et27 as yours is a pre-LCI
      10-18-2015, 06:21 AM   #8
Nick91
Drives: E91
What's the difference from pre lci to lci. I thought body and suspension was the same.
      10-18-2015, 06:47 AM   #9
Wayne-G
Wayne-G's Avatar
104
Drives: MG F30 330d Msport xDrive
Lci Model has widened rear track by 8mm I believe
      10-18-2015, 07:43 AM   #10
Nick91
Drives: E91
Oh right thanks for the info.
      10-18-2015, 10:40 AM   #11
Digitalize
Photographer
Digitalize's Avatar
412
Drives: 320D
9.5 ET27 will be fairly close IMO with a 255. I've got 9.5 ET45 and I tried an 18mm spacer, I felt like it would rub so decided against it. Never actually tried it just based on looking.
