10-15-2015, 12:56 PM | #1 |
404
Rep 962
Aisin transmission performance
Has anyone had the opportunity to compare the transmission in the new X1 to the ZF8? How is the programming and shift speeds?
10-15-2015, 04:12 PM | #2 |
85
Rep 280
I'm afraid its inferior just by comparing official BMW data for both, the ZF8 usually is rated faster than manual while using less fuel.
The Aisin however is exactly the opposite, its rated slower than manual and is using more fuel. (comparing german versions as you guys won't have the manual in the X1 as far as I know) However after watching some reviews some say its fast and smooth and shifts at the right time to the right gear, so it can't be that bad. Last edited by Ganxxta; 10-16-2015 at 01:32 PM.. |
10-17-2015, 01:14 PM | #6 | |
Rep 11
As for the new X1, in German spec: - the 0-100 km time is identical for manual and auto on the sDrive18i, the sDrive 18d, and the xDrive 20d; - the top speed is identical for manual and auto on the sDrive 18d and the xDrive 20d; - the fuel consumption is identical for manual and auto on the xDrive 18d and the xDrive 20d. - while the auto performs a little worse than the manual in a few other cases. But viewed altogether, the differences are not significant enough to justify your claim that the Aisin is worse than the ZF. |
10-17-2015, 01:47 PM | #7 |
85
Rep 280
The sDrive 18i will get a 6 Speed Auto, so no comparison to the ZF8 possible, maybe due to less gears it will be lighter which might help the overall package.
The xDrive 20d has a rated fuel consumption of 4.9l against 4.8l in the manual But in general you are right that it should not be worse than the manual, also considering that with auto there is additional weight. I didn't get the opportunity to drive one myself yet, however the ZF8 that I have is pretty good I must say. |
10-17-2015, 02:30 PM | #8 |
Rep 11
10-17-2015, 03:02 PM | #9 |
85
Rep 280
10-17-2015, 03:59 PM | #10 | |
Rep 11
10-17-2015, 06:45 PM | #11 |
85
Rep 280
Haha might be
The European fuel consumption figures are totally unrealistic anyway, so 0.1l more or less doesn't matter much. The only indication that this list shows for the 20d is that the auto uses less in the city and more on the highway than the manual (which is weird, since 8 gears should have at least 1 overdrive extra long gear ratio for highway speeds compared to the 6 speed manual). Next week is the official premiere at my dealer so I want to try to have a test drive in the X1 to be able to compare it to the ZF8 in my F32. |
10-17-2015, 07:33 PM | #12 | |
Rep 11
But please do let us know what you think of the quality of the gearbox after you have tried it. |
10-27-2015, 12:35 AM | #13 |
280
Rep 1,491
Having test driven the X1 xDrive20d with this transmission, and because I currently own a F20 M135i with the ZF8AT, I can confirm the Aisin transmission is very smooth, and changes rapidly. I didn't test it as a high performance auto, as per the ZF, because the X1 isn't that sort of car, but I reckon most owners will be very satisfied with the Aisin.
Peugeot T9 308 GTi 270 Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182. |
10-27-2015, 12:28 PM | #14 | |
Rep 11
11-13-2015, 04:49 AM | #15 | |
513
Rep 985
However, given the choice, i'd pick the ZF. It's more "reliable" and changes a tad faster imo, but it's a close race.
3 series: E30: 89 325i, E36: 92 325iC, 94 320iC, 96 320i Convertible, 94 320iaC, E46: 99 320ia, E90: 06 318i Le mans, E91: 07 318dt
5 series: E39: 97 520ia, 01 530Dat, E61: 09 520Dat X series: E83 05 X3 2.0d, E84 10' X1 2.0 X-drive DA, F25 13' 2.0da X-drive. |
11-15-2015, 11:16 PM | #16 |
280
Rep 1,491
Yesterday, I had the opportunity to drive the new 3 series 330 back to back with the X1, both with auto transmissions.
I felt the Aisin actually had smoother shifts that were just as fast as the ZF, including when using the paddles; they're both great A/Ts, I reckon. As to reliability, it's a bit too early to tell, as the Aisin has only been in use since 2013, but it does have a fairly wide range of automotive customers in addition to BMW: Chevrolet; Lexus: Toyota: Volvo, to name a few.
Xorbitman46.50 |
11-16-2015, 12:34 AM | #17 | |
iPhone/iPad Developer
52
Rep 249
FWIW, I doubt 95% of drivers would be able to tell any difference in real-world driving between the ZF and the Aisin. |
Xorbitman46.50 |
11-16-2015, 02:04 AM | #18 |
92
Rep 236
I was quite happy and impressed with the Aisin 8AT on my test drives. I think without back to back drives with a ZF car it would be hard to tell the difference. The Aisin is way ahead of my Merc's slow, clunky and dumb 7G-DCT. My only gripe with the X1 gearbox is having a mechanical shifter rather than an electronic one. I reckon since Toyota and Lexus are using this gearbox it can't be too bad, given their brands' reputation for reliability.
11-16-2015, 02:34 AM | #19 |
280
Rep 1,491
Yes, Aisin has been around for a good while, with units including its longitudinal 8AT in a number of high performance cars. Lexus/Toyota is renown for its supply chain rigor, so I'm not worried. The physical shifter (vs ZF electronic) is something you'll notice only if you have another car with electronic shifter.
07-07-2019, 09:58 AM | #20 | |
19
Rep 130
07-08-2019, 02:13 AM | #21 |
280
Rep 1,491
It will be the Aisin, in transverse configuration. The ZF 8AT is not fitted to any F48 X1 model
07-08-2019, 02:17 AM | #22 | ||
280
Rep 1,491
