Tyre profile size
10-12-2015, 08:53 AM | #1 |
26
Rep 515
Tyre profile size
Bit of a noob question.
If I increase the profile on my fronts and rears will it increase my ground clearance? Reason being, I catch on a gate stop at my apartment block and it's driving me insane!! Will raising the profile have any other effects? I'm guessing it will close the arch gap a little. Also plan to ditch run flats at the same time and maybe go a bit wider, read that a lot of people do. I'm running MV4's currently |
10-12-2015, 09:01 AM | #2 |
38
Rep 686
10-13-2015, 01:25 AM | #6 |
26
Rep 515
What are the offsets? (To input into that website)
It depends how many people are in the car, if I'm alone then it just tips it sometimes. If I have a full car then it's a huge clunk off something. Working on moving house... And I debated giving it a quick hit with a sledge hammer but the gate will then go over it. Because it only just touches it at the moment. How much will it throw the speedo out? Is there something that can be done to correct that? |
10-13-2015, 05:11 AM | #7 | |
448
Rep 3,312
That way you don't have to worry about the rims themselves. It will give you the different measurements from changing and the percentage differences for things like speedo. You can't do anything to compensate for the speedo discrepancy when altering tyre sizes. Also if you are getting quite a hit then you'd need to really alter the profile which isn't wise to do as you should ideally keep it as close to stock. Perhaps you need a lift kit or air suspension...
E92 335i / M3 Hybrid - The Build
10-13-2015, 08:49 AM | #8 |
30
Rep 210
On my LCI E93 i'm running f30 403s with 225/40/19 and 255/35/19 which is bigger than the E93 profile of 225/35/19/ and 255/30/19 and my speedo is now spot on instead of reading over when comparing to GPS.
