Rear Juddering noise from rear of E92 335D
10-07-2015, 03:24 PM | #1 |
24
Rep 92
I seem to be get a juddering noise coming from the rear of my E92.
It doesn't happen all the time. Only on some occasions. I have a sticking caliper on the rear driver side which is quite bad now. I am going to fix this tomorrow evening. Could this be the cause of the juddering? The juddering noise sounds like it is coming from the opposite side but I could be wrong. Thanks for any help! |
10-08-2015, 09:18 AM | #3 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
You'll be best advised to change discs and pads too. If your caliper is sticking it will probably have caused the pad/s to overheat and deposit pad material onto the discs.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
10-08-2015, 03:16 PM | #4 | |
283
Rep 2,796
Take a photo if each disc(side on flat)and post em up for a look done this a number of times for people on here it's interesting to view something like this actually. I'd also wager your discs are at least lipped on the outer surface area(if so they'll be worse on the inner surface)and I'd also suspect the discs apart from any discolouring will be scored as well, seen this symptom too many times now and ate all systematic with the sort of issues you're facing, if pads have been put on already lipped corroded or worn discs as so many people sadly do this will create issues as well. |
