car eating rear tires
10-05-2015, 07:22 PM | #1 |
34
Rep 142
Hello,
have problem and I don't know if it's normal for BMW E90 (sport package I have to mention, maybe it's important). I had 2.5 years ago cheap non run-flat rear tires (don't even remember brand name) and I wasn't surprised that it lasted only 1 year. I replaced them with Michelin Pilot Sport A/S 3. It's been only 21000 miles since then and again I have rears almost gone. Thread pattern is the same: like outer part has bigger diameter than inner. The more we move from outer to inner parts of the tire the more it's worn. So is it normal or not ? Maybe soft tires is bad for stiff suspension ? |
10-05-2015, 09:26 PM | #2 |
59
Rep 661
How's your driving style? That'll be the biggest influence on tire wear. If you spin the tires and go full throttle a lot then they'll wear quicker. If the inner is much more worn then it's a camber issue. Mine were worn somewhat evenly across the tire. Granted the inner was slightly more worn but I'm on coils and am running slightly more aggressive camber than stock.
These tires aren't that soft though, especially compared to a summer tire. However, this tire is more like a summer tire handling wise (PSS) than the previous Michelin A/S tire. My car is FBO and occasionally run e85 e40 mix and I went through a set of AS3's in 25k miles. I do the occasional drift around a big hairpin by my house and they spin if I am too aggressive in first. I wouldn't say your car is eating tires, maybe a little shorter tire life than normal but not crazy especially if your car is tuned. I only got 9k out of a set of DWS tires...last time I ever ran Continental. |
10-05-2015, 09:39 PM | #3 |
28
Rep 409
I only got 13,000 out of my rear A/S 3's. I definitely have a camber issue as outside was 5/32nd and inside was at 2/32nd, though I'd say you did well in terms of your driving style.
I'll be having an alignment next week and trying to relax a bit more behind the wheel
2009 E92 335i M-Sport - MHD Stage One - BMW Performance Exhaust - BMS Oil Catch Can - CDV Delete - K&N Panel Filter - Arc Angel H8 bulbs - Gloss Black Kidney Grills - Painted Reflectors - VRSF Charge Pipe
10-05-2015, 09:55 PM | #4 |
52
Rep 278
Looks like normal stock camber to me. Same as mine, and almost every other e92 I've seen. Problem is being staggered, we can't rotate like a square set up.
10-05-2015, 10:31 PM | #5 |
Where'd my VTEC go?
481
Rep 6,067
Hard to tell anything from that picture. Take a picture with your camera right behind the wheel (under the bumper) so you get a straight shot across the whole width of the tire.
21k miles doesn't sound too out of line.
10-05-2015, 11:40 PM | #6 |
700
Rep 1,227
i would consider that to be right on the money for the mileage to expect from that tire.
Michelin warranties that specific tire for 45,000 Miles but then cuts that in half so 22,500 if you have a staggered setup(Wider rear vs front). Which sport package does. At 21,000 you are right at what you should expect. Keep in mind that you can buy higher mileage warranty tires which will last longer but don't expect stellar performance out of them. That being said i personally average about 10-11,000 miles for my rears running Michelin Pilot Super Sports. BTW always make sure you are getting an alignment every year or two at the least. It does appear you have the slightest camber wear and an alignment will help a bit. But BMW actually specifies negative camber from the factory. ( this means the inside part of your tire will always wear out faster) I always say... you bought a BMW you gotta pay to play my friend. This is not a Toyota Corolla your maintenance costs will be more than 3x what a Corolla would cost. Tires included. |
10-05-2015, 11:45 PM | #8 |
60
Rep 227
Proper inflation is important. Proper alignment specs are necessary when tires are NEW.
'11 LBM E90 335i M-Sport (Current)
'12 AWP II MDX Tech (Hers) '07 NBP TL Type-S 6MT (Sold) "From a Lifesaver to a Soulsaver" <-- Click |
10-05-2015, 11:59 PM | #9 |
163
Rep 276
Drives: F10 M5 Comp 6-spd
Not too far off what most folks see. I wore the right side tires through on the inner edge until they essentially popped about a week apart. The tires had about 20k onthem. I attribute this to three perfect right handers i charge daily on the way to work. Driving harder will wear those tires especially those with lower treadwear ratings. Mine were Bridgestone RE050a's with a 140 rating. Not all tire manufacturers rate their treadwear the same so the number can differ from brand to brand if that makes sense.
Next time I plan on buying non run flats and going for a longer lived tire at the expense of performance. Harder tires can actually be quite fun still...
2015 M5 Comp 6-spd manual
1972 2002 2003 Audi TT Coupe 225 2011 Highlander 4WD |
10-06-2015, 09:45 AM | #10 |
34
Rep 142
Thanks guys for the input.
I guess it's kind of normal. Not what I expected from non-runflats. I did alignment regularly as well as balancing tires and was controlling tire pressure. My thoughts about that: I guess the more stiffer tire the more longer it's gonna live, especially for sport suspension and staggered wheels. So tend to think that run flats is not that bad choice as I thought before cause this suspension chews and spits out all tires that do not resist Last edited by snayko; 10-06-2015 at 09:50 AM.. |
10-06-2015, 10:45 AM | #12 |
851
Rep 2,793
Do you rotate your tires every 10000km?
I have over 50k on a set of Michelin as-3's and still have lots of tread left....mind you I have x-drive...and rotate every 10 k |
10-06-2015, 12:05 PM | #14 |
28
Rep 409
I think he has a staggered setup, so he can't. I wish I could rotate as well.
10-06-2015, 12:50 PM | #15 | |
851
Rep 2,793
10-06-2015, 02:35 PM | #16 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
Get an alignment and specify for maximum tire life (may have too much negative camber or your toe is out of spec).
10-06-2015, 02:42 PM | #17 |
105
Rep 955
how is your alignment and what are your driving habits? I replace my rears every year and my fronts every two years.... Why? Because I love to drive my car moderate with several moments of thrilling acceleration in between.
I make sure my alignment and suspension is GTG. For those of us that have the mod bug it comes with a lead foot. Why mod the car and not use it... |
10-06-2015, 02:45 PM | #18 |
215
Rep 988
I only got about 10k out of the rear pair of AS3 on my previous 335i. I abused them occasionally but that's a little disappointing
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
10-06-2015, 03:54 PM | #19 |
28
Rep 409
I'm not the only one with this issue. Phew
10-06-2015, 10:05 PM | #20 |
141
Rep 989
Camber isn't actually what causes premature tire wear. Having toe out of spec is a bigger issue. Did you ever swap them side to side? Since they are asymmetrical tires you can just swap the rears from left to right.
And 20+ thousand miles isn't that bad for that type of tire as others have said. |
10-07-2015, 03:00 PM | #21 |
148
Rep 208
Prior to purchasing my bimmer about a month ago this was something I researched to death and having a staggered setup I simply "accepted" the fact that this is a car that loves to eat tires so if I get 15k from the rear tires I will be happy.
10-07-2015, 03:46 PM | #22 |
28
Rep 409
Rightfully so, with summer tires I'd guess the average is around 12k.
