gladen upgrade - no bass
10-04-2015, 03:23 PM | #1 |
159
Rep 548
could do with some help from those of you experienced with the gladen kit.
i have the full gladen kit, so the 4 ch amp, the gladen subs mids and tweets. gladen one kit. using the gladen harness too. I've got the hiss, which research leads me to believe is down to the routing of the harness round the fusebox. will have a look at that. but the bigger issue for me right now is lack of bass. i was expecting some sort of kick from the subs, im not getting anything. there is some bass there, but if i move the audio to the back speakers, its coming from there. im not sure the guy who wired it in has got it right, anyone got any ideas for where i should start checking? or are there any diagrams for this install? i think the problem is probably with the harness and its use. as i understand it, it grabs the audio and pumps it through two channels to provide sound for the fronts. how does this feed the subs? |
10-05-2015, 03:10 AM | #2 |
840
Rep 1,993
Drives: F30 335d
I have the Gladen BMW One line kit as well, presuming you have the Mosconi 120.4 or similar? The subs are wired directly to the amp. Did you installer set the gains correctly? Did you set the amp to 2 channel mode? If it's set to 4 channel you won't get any sound from the subs - because you have no input into channels 3 and 4.
Hope that helps.
if I've helped - an Appreciate would be, er, very appreciated!
10-05-2015, 06:28 AM | #3 |
159
Rep 548
thanks mate, that makes total sense. hopefully get chance to lift the boot carpet tonight and look and see if its set to 2 ch mode.
i have the gladen amp with mine, not the mosconi one. |
10-12-2015, 04:54 AM | #4 |
159
Rep 548
thanks for the help mate, you were bang on. the amp had moved and turned the 3/4 channels off, by pressing one of the switches. have put screws in it now, it won't move again.
10-12-2015, 05:07 AM | #5 |
840
Rep 1,993
Drives: F30 335d
No worries
