Combox Retrofit
10-04-2015, 12:16 PM | #1 |
281
Rep 1,524
Combox Retrofit
Hi, I have a 2009 330d with factory fitted CIC, bluetooth, USB in armrest, BMW online and assist. I am looking in doing a combox retrofit.
Current TCU in boot, I have done research into this but still have a few questions; - The CIC needs to have the correct firmware. It has been updated previously as I can update the maps via USB, i believe this feature came out in 2013. to find out if my CIC has the correct firmware? I have DIS, NCS and INPA. - I can get a plug and play harness from a member which should make the installation straight forward. - I need to do coding at the end but cant find a guide on what needs to be done. Any links? I have done coding before using NCS. Thank you |
10-08-2015, 06:38 AM | #3 |
26
Rep 351
How did you update your cic firmware?
I am in same position as you 2010 320d with no combox looking for retrofit. Itany seems to be a good guy to speak to on here. |
10-08-2015, 09:13 AM | #4 | |
456
Rep 2,749
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
10-28-2015, 10:06 AM | #5 |
281
Rep 1,524
Yes my car being a 2009 is before combox became a standard fit.
But i believe the CIC software has been updated in the past, so how do i find out if my current CIC software version is compatible? |
10-28-2015, 10:33 AM | #6 | |
126
Rep 2,022
I can safely say, your CIC won't be fully combox friendly (I.e if you want BMW apps). |
10-28-2015, 10:39 AM | #7 |
281
Rep 1,524
I have googled it and the closest I have found is Best way to check CIC firmware is read from NCS expert. After codieraten_lessen will show a current status from CIC.C08 to CIC.C1A
So this will tell me what firmware i am on, but what is the minimum firmware required to be combox compatible? How do you know my CIC will not be fully combox compatible? |
10-28-2015, 11:42 AM | #8 | |
126
Rep 2,022
You need C16 for combox & apps. Last edited by jammy78; 11-18-2015 at 04:02 PM.. |
10-30-2015, 10:10 AM | #12 |
281
Rep 1,524
10-30-2015, 11:11 AM | #13 |
126
Rep 2,022
11-18-2015, 03:48 PM | #16 |
37
Rep 333
Combox
12-06-2015, 02:00 PM | #18 |
Coding ECU's remotely
445
Rep 1,176
You can only update the CIC with an ICOM interface.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
12-06-2015, 02:47 PM | #20 |
445
Rep 1,176
Not at the moment, I'm looking to get an ICOM in the new year.
12-06-2015, 03:15 PM | #21 |
281
Rep 1,524
12-08-2015, 01:30 PM | #22 |
445
Rep 1,176
Newcastle
