proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > AUSTRALIA
      10-04-2015, 08:46 AM   #1
simpelton
Australia
33
Drives: F80 M3
Fuel/Petrol/Gas/98
Back in the day, had a work colleague with a fully worked R34 who swore by filling up only at shell. Recently family member bought a cayenne gts, dealer said fill with only shell 98. I use 98 but fill up where ever, caltex or BP typically.
Is a 98 a 98 or is shell really superior? What do you all use/recommend?
P.S. talking about 98 RON
      10-04-2015, 03:48 PM   #2
Øzzy
Australia
21
Drives: M4
Back in the days Shell used to be the better fuel, not anymore. The Caltex / BP are the better fuel now. The Shell 98 formula now has a yellow dye in it which over time forms like a blanket in your fuel tank. BP/Caltex which is the same fuel from the same refinery is a better option as they don't use any dyes. As a motorcycle mechanic I see this on a daily bases who uses what, and trust me bikes are more sensitive when it comes to 98 fuels.
In saying this I will not be able to guaranty that any fuel will be clean... in January this year BP admitted of an mistake made at the refinery with the 98 formula which by mistake was added 20% ethanol. You may remember this as it was on the news with all the Porches and other sports cars all broken done within 1km from the stations
Number one rule is to make sure you fill up from bigger stations which are on main roads, they tend to re-fill the 98 stock up much quicker than smaller stations which means fresher fuel. Remember that smaller stations usually are stocked up with older batches in which case you are better off with fresh 91 since a batch of 30 day old 98 is probably weak as
      10-04-2015, 06:10 PM   #3
chromedome
chromedome's Avatar
Australia
21
Drives: F82 M4 Alpine White, 911 997.2
2016 BMW  [0.00]
This can be a bit of a religious argument...
My experience, with bikes (BMW's too...) was that I found that if I didn't ride for a few weeks after filling up with the 'newer' fuels - 98 from BP or Shell - which have additives in them the fuel would go 'stale' very quickly.
Not sure of the actual chemistry but as the previous poster mentioned, bikes have a much lower tolerance for bad fuel than cars. I was having issues with power and starting.
The BMW dealer mentioned it may be fuel - I've since had this confirmed by a few motorcycle guys.
So to your point - I don't think its necessarily the brand but the 'freshness' of the fuel and how regularly you drive.
      10-04-2015, 08:44 PM   #4
Øzzy
Australia
21
Drives: M4
Who do you ride with chromedome?
Come riding with us
Go to my website www.ozracing.biz and at the bottom right of the page enter my forum and join. I do regular rides almost every Sunday weather permitting
      10-05-2015, 02:27 AM   #5
simpelton
Australia
33
Drives: F80 M3
Intriguing, was never aware that the fuel deteriorates, I have a tank that sits around for a couple weeks sometimes, so will have to fill just before going for a spin and burn it out before heading back .... That should be easy :-)
I don't recall about the fuel mix up, did they pay comp. for any damage caused?
      10-05-2015, 02:42 AM   #6
Øzzy
Australia
21
Drives: M4
Yes
      10-05-2015, 02:51 AM   #7
simpelton
Australia
33
Drives: F80 M3
Makes my life easier, I tend to stick to Caltex but only due to convenience. We seem to have consensus, fresh fuel it is.
      10-06-2015, 08:22 AM   #8
simpelton
Australia
33
Drives: F80 M3
What about oil changes, stick to the schedule or change more often - tracking the car probably clouds the answer to this I guess
      11-27-2015, 02:59 PM   #9
AC-S
Registered Member
Australia
14
Drives: M4
It all depends what oil you are using
If you use a good quality oil like Mobile 1 then once a year as per schedule or 10000km should be ok, if you do track days like me then I am very anal about it and do an oil change after every track day
      11-27-2015, 11:16 PM   #10
simpelton
Australia
33
Drives: F80 M3
What oil do they use when the car is serviced?
      11-29-2015, 01:59 AM   #11
AC-S
Registered Member
Australia
14
Drives: M4
When I do my own oil changes I use Mobil 1 0W-40
      11-29-2015, 08:54 AM   #12
Explicit
Explicit's Avatar
Australia
92
Drives: Germany & Japan
As stated above, stick to factory service intervals. If you track hard then an oil change shortly after is good insurance.
F80 M3 Fire Orange - F15 M50D - Mineral White
W114 C63 Restomod - BNR32 GTR
@_r32gtr_
www.racewars.com.au
f80post
