transmission pan - bolts - gaskets
09-25-2015, 08:50 PM | #1 |
Rep 122
my car: 09 328i Xdrive gm transmission Replaced my filter, fluid and gasket. and when doing so I over tightened the bolts slightly, so it leaked. The next day I purchased a new pan an another gasket. For sale: The gasket that will come with the pan, was on for one day and is oem bmw. You can also have the original if wanted, it's surprisingly in good shape as well. The pan is original and will need to be straightened out to fit properly.Just a slight hump where the bolts go. But reading online it is very easy and common to do. I paid little over two hundred for the new one, so save yourself some money if yours has been damaged. I also replaced all my differential fluid and plugs. So I have two fill plugs for diff that in very good condition. And 32 aluminum bolts for transmission pan |
