BMW Attacked by Wild Turkeys! - 335i Paint Correction - 22ple VX3 Paint Coating
09-18-2015, 06:49 AM | #1 |
360
Rep 5,052
This vehicle belongs to a repeat customer of ours. You might remember this vehicle from a previous thread when we did a major overhaul on the paint for this owner shortly after he purchased the car (click here to see the write up from last year). If you didn't see that post, here is a little summary...
... well this year it returns to us due to an unlikely event that left scratches all along the sides of the vehicle (again). The car was attacked by wild turkeys. Yep. Turkeys. They apparently saw their crystal clear reflection and decided to try to show that 'other turkey' who was boss. Long story short, the customer wanted us to correct the sides of the vehicle to remove as much of the damage as we could while still being conservative. We also polished the rest of the vehicle to remove some water spotting, dullness, and swirls that had been introduced over the last year. I've been told the vehicle will now be parked in the garage at all times, so I hope we don't see this one in for correction for many years. It turned out great when it was all said and done... I really like this color! Process Tires: Tuf Shine Tire Cleaner & Tire Brush Wheels: Sonax Full Effect Wheel Cleaner & Various Brushes Pre-Wash: CG Citrus Wash via Foam Lance then pressure rinse Wash: CG Citrus Wash Chemical Decontamination: CarPro IronX & Stoner Tarminator Paint Decontamination: Medium Grade Speedy Prep Towel with Nanoskin Glide as Lubrication Tape trim and other areas of concern Paint Thickness Readings Taken Compound/Cutting (sides only): Griot's Fast Cutting Creme on Fast Cutting MF Pads via Griot's G21, Rupes LHR21ES and Rupes LHR75e Polishing (entire car): Griot's Correction Creme & Correcting Pad via Griot's G21, Rupes LHR21ES and Rupes LHR75e Coating Prep/Polishing Oil Removal: 50% IPA Ceramic Paint Coating: 22ple VX3 Signature Glass Coating Glass: Meguiar's D120 Tire Dressing: CarPro PERL Upon in initial inspection, it was clear that the paint needed some correction to enhance its appearance. There were some deeper defects that would also need to be addressed. We began with an extensive exterior cleaning and decontamination process. The vehicle was then brought inside for further inspection. The paint had a fair amount of water staining, swirls, and scratches. We were not after 100% defect removal as the paint was quite thin, and the majority of the vehicle had been repainted so caution is always used. I was able to make a considerable improvement to the color and depth of the paint. Hood before Hood after Checking my work in the sun Trunk before Trunk after 50/50 on door after compounding quarter panel before quarter panel after compounding bumper before bumper after compounding The paint was then coated with a thick layer of 22ple VX3 paint coating This was allowed to flash, and then was wiped away to a mirror finish The car looked great afterwards. The paint was extremely glossy! The majority of defects were removed leaving clear reflections and vibrant metallic flake. Hopefully this car will remain in this amazing shape for a couple more years before we get to get our pads dirty on it again. Links to all products used are provided at the beginning of this article. As always, thanks for reading, and let me know if you have any questions! Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
09-18-2015, 10:55 AM | #2 |
3788
Rep 5,776
Looks really nice. The pads you used are fairly aggressive I imagine?
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
09-18-2015, 01:18 PM | #3 | |
360
Rep 5,052
Correct, the Fast Correcting Microfiber Pads & Fast Correcting Creme are an aggressive combo that is capable of quickly leveling defects. Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
09-18-2015, 11:13 PM | #5 |
3788
Rep 5,776
That car looks to be BSM paint? That gives me hope that I can get mine looking something like that someday.
09-20-2015, 11:52 AM | #6 | |
360
Rep 5,052
Black Sapphire Metallic is very similar in terms of hardness, check out our thread "Black Sapphire Metallic X5 - Corrected & Coated" for an example of BSM correction. Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
09-20-2015, 04:20 PM | #7 |
3788
Rep 5,776
Yeah, I remember that one--Do you think I can get that kind of correction with Meguiers mirror glaze #1 using the white pad or orange pad I purchased from you? The swirls are light at this point but I am still having a hard time getting the fine ones out. Yeah...I'm still trying to find that technique...I've watched your vids and others..remember I have the shurhold polisher.
09-21-2015, 06:49 AM | #8 | |
360
Rep 5,052
Meguiar's #1 Medium Cut Cleaner would not be my choice of abrasive. SBM is quite hard, and therefore will likely require a cutting pad such as a microfiber cutting disc and a compound like Meguair's D300 or M100. Finish with a light polish such as M205 on a white polishing pad. I've had great luck removing defects on SBM with these products. Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
09-23-2015, 05:50 PM | #10 |
Rep 158
Drives: 2011 335i Sedan
Dude! It's so shiny now, the turkeys will be back with a vengeance!
09-25-2015, 01:56 PM | #12 |
687
Rep 2,770
Nice improvement! The car looks awesome with the 22ple on it.
I am a little surprised at the condition of the paint (turkeys notwithstanding) after only a year. Wouldn't you expect the CQuartz to prevent scratches better than that? Or did the owner not practice good paint maintenance (auto car wash)?
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
09-25-2015, 02:11 PM | #13 | |
360
Rep 5,052
09-25-2015, 04:10 PM | #15 | |
360
Rep 5,052
My name is Zach McGovern, I am a professional detailer who does some work for Detailed Image as an author for their Ask-A-Pro Blog and by providing support for the forums they sponsor. Detailed Image is an industry leading retailer of detailing supplies and they are located in Albany NY. Sorry for the confusion. Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
10-22-2015, 01:46 PM | #17 |
360
Rep 5,052
Thank you very much!
11-24-2015, 09:35 AM | #19 |
360
Rep 5,052
12-18-2015, 03:12 PM | #20 |
14
Rep 37
Drives: 320d, M Sport Coupe
WOW!!!! Like... Damn!! I don't think I've seen a finish look that wet and shiny before. Damn (again).
12-21-2015, 10:21 AM | #21 |
360
Rep 5,052
01-16-2016, 03:39 PM | #22 |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
Beautiful job on this car. Prior to seeing the "after" pictures, I was thinking, no way he's going to get some of those scratches out on the rear bumper and quarter panel. But damn you did it! You got rid of them. I wish you were in Socal so I could have you do this to my car.
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
