Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > 335i cold start and fuel
      09-13-2015, 11:30 AM   #1
pmmcbl
35
Drives: E91 335i M-Sport
Hello all.
There are plenty on notes on forums about white smoke or blue from cold starts on 335i models.
I couldn't find what my car is currently suffering.
Only on cold starts I get the following and wanted to know if you guys get it or not.
Start the car first time.
Ok for around 3 seconds
Then I get what appears to be condensation for around 3 seconds, I can smell fuel.
After that not smoke or smell for a while.
Then after maybe 1 minute I get normal condensation
Is this normal? Thank you
      09-13-2015, 12:17 PM   #2
Aragorn30d
175
Drives: E90 330d
Sounds fine tbh. Engines run rich when they're first started, and it takes a bit of time for the cats to come up to temperature to be able to catalyse the excess fuel, so you'll get some fuel smell immediately after starting.
Condensation/Steam/"white smoke" is just water from the inside of the exhaust heating up and coming out as steam. It happens because as the exhuast cools, moisture condenses inside the exhaust system. The engine itself also produces water in the exhaust gas, which can condense on the cold pipework, before evaporating again once it heats up.
Blue smoke on startup could indicate a potential issue, but its more common than you'd think, especially on decatted turbocharged engines. Usually you wont even notice it unless your looking for it.
Unless it was reeking out blue smoke when driving or idling when warm i wouldnt be all that worried.
      09-13-2015, 01:00 PM   #3
pmmcbl
35
Thank you.
Not worried to be honest, just steam but didn't expect it to have it during a start up. Steam normally kicks in after a minute or two.
      09-14-2015, 04:11 AM   #4
AWSAWS
AWSAWS's Avatar
283
Drives: E92 GC Turbos, FBO, 335i DCT
Originally Posted by pmmcbl View Post
Thank you.
I imagine exhaust gas which is full of steam gets trapped in the exhaust system as soon as the engine goes off and condenses. Then when the engine and exhaust heats, (next time the car is started) it forms steam again.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos)
11.74@129mph (GC Turbos)
      09-14-2015, 07:48 AM   #5
Dann
Dann's Avatar
133
Drives: E90 LCi 335i
My E36 used to steam like crazy when the ambient temps were colder (like would make a proper smoke cloud)
The 335i has started steaming a little bit now and will probably get worse as temps drop.
Just condensation and nothing to worry about unless it's thick and White or Blue.
      09-14-2015, 04:17 PM   #6
pmmcbl
35
Thank you guys, feedback very welcomed. Yes, the temp has been low in the morning and this is when I noticed.
I had a closer look today and does look condensation to me together with Fuel smell. The steam is clear until it reaches the end of the pipe and turns into steam. Just odd when it goes away for a minute before your normal code station kicks in.
Never seen that on any other car. Glad I'm not the only one.
Thank you
