What I get to see
09-12-2015, 03:43 PM | #1 |
283
Rep 2,796
What I get to see
Been asked apart from what I post on here what else do I see> Well here some of the emerging things I'm getting to see and the odd one off!
If you own one of the 4 cylinder engines don't be too surprised to greeted with the dreaded issue re cam shaft and crank shaft corrolation, most garages assume its a cam or crank sensor fault sadly 90%+ of the time its this broken chain guides. Chain will become slack perhaps jump on average 2-3 teeth you therefore strip everything down replace the guides re assemble refitting the vanos units (we check the vanos units and actuators as well for issues pre work to see if there are any faults) and cary out the all important re timing(special timing tools requied for this) we are seeing more and more of these engine coming our way with issues, sometimes apart from the above other things have been going on mainly IMO due to servicing issues, again something that we do investigate. Below is a car that again damaged guides tensioner was tired to say the least and it had started to die but if caught you can save an engine. CBS on these cars IMO allows oil service to go for too long. The one below had followed BMW's CBS schedule haveing coverd just over 31000 miles but as you'll see too late Things like walnut blasting we are now well known for turing your 335i's valves from this to this but solving other poor running issues on 335i's as well as 330i's and 325i's is now becoming more common, poor tickover lumpy running can be more than the usual plugs sometimes a misfire cannot be wholly put in the plug and coil camp so we check the injecors with a borscope camera and find the answer to back up the diagnostic results here below is a live video of a failing 335i injector the mist you can see is the proof of a leaking injector and one these cars damn difficult to prove unless you probe. Swirl flaps leaking and their consiquences re being ingested are well documented. On the earlier E9X diesels your swirl flaps are identical to those found in the E46's and sadly this happens the above car lost 1 swirl flap the second one on the last picture was broken away and was stuck where you see it. Look at how the manifolds coked up as well all 4 ports were like this on this car. On the later cars they simply leak but at least when removed they do appear to be more substantual but as you can see below they still have issue's namily the casings start to break apart and are erroded over time, therefore same story applies unless you've got a real late diesel get them out and replace them with ali blanks Apart from the other stuff I see reguarly post re brakes and solving the odd puzzle re why the car seems to vibrate or are noisy under braking or while driving and this one's a peach which as you may be able to gather is ususally down to corrosion, lipped scored discs and pads wearing unevenily(which can be easily spotted) due to cracking Leaking gear box sump's or more to the point reported gear box thumps while driving or stopping that turn out to be leaking sump's and pilot sleeves when inspected are again common we do as you may know shed loads of these without drama and are all too common. I do get to see some more intersting stuff. With M5's & M6's now becoming so much more affordable we are seeing a few come our way now and the engine's to die for If you're going to buy one of these be prepared to have an open wallet policy with your bank account. One if not the biggest single issue rests on the clutch/flywheel assembly. They wear out: No surprise but the biggest single issue re these is actually the set up and the owners playing with the settings, we see quite a few that are simply not set up correctly, essentually robbing the car of performance plus accelerating clutch and flywheel wear The only option is to repalce both the flywheel and clutch plus internal ball pin spring and clutch fork which will cost over double the average manual clutch and flywheel repalcement on your 325d for instance therefore the gearbox (which is a good deal heavier and larger than your average manual needs to come out and once re fitted (again we check other components such as the hydraulic pump, pressure accumulator & pressure sensors)-which are common issues as well, its vital that the gear box is set up all adapataions are re set and allow the car to adapt to its new gearbox. We do these now reguarly and they drive so much better for it. On the subect of clutchs we see a few where people don't know what the smell is from the engine area and why the revs rise and the car doesn't seem to move that quicky says it all really, but its surprisingly common. ABS/DSC issues are rife either hydro or the dreaded drive shaft reluctor rings seem to be BMW fav's at the moment on both 4 & 6 cylinder cars, though the 4 cylinders seem more of an issue re drive shafts for sure Solving the mystery re vibration while driving can be many things but I'd say a good 40% of the issues lie with these things tyres are often over looked or people just look at the outer section of the tyre 90% of BMW's we see wear on the inner 1/3 of the tyre or wear due to under/over inflation. So check your tyres reguarly. Left the best to last and again goes back to M5's & M6's namily the engine rare to have a failure but we've seen them hence this poor old Alan and 2 M5 engines, one bare & one knackered engine from the car in question(2 injectors didn't shut down causing CAT to disintergrate and killed cylinder 4 & 5)and the old engine awaiting all ancelleries to be swapped over. And that's what I see. Thanks for reading Last edited by old grey steve; 09-12-2015 at 04:13 PM.. |
09-12-2015, 07:06 PM | #4 |
111
Rep 716
Great post ! so definitely stay away from the 4 cylinders ! what about the n52 325i would you say that is a decent engine other than the ticking ?
BMW 325i M sport - Custom stainless exhaust ( 335i set up ) - Piano black interior trim - Gloss black kidney grills - Ferric grey 18" MV3 alloys -
09-13-2015, 03:27 AM | #8 | ||
283
Rep 2,796
Indeed an M47 unit, on a 04 plate 320CD, the later cars as I've posted above have a more tolerant swirl flap design, but though they are not prone to being ingested like the early E9X series cars/all E46 cars they still leak and the casings as pictured get eroded and that plastic can only go in one direction and that's into the inlets and combustion chamber, like a swirl flap. |
09-13-2015, 03:16 PM | #10 |
111
Rep 716
[QUOTE=old grey steve;18571701]IMO and what I see you get more issues with the 4 cylinder cars than you get with the 6 cylinder cars in terms of engine related issues at least, the 6 cylinder cars seem a bit more tolerant but that's not to say that they are bullet proof, they aren't (especially when it comes to things like injectors) they have their own little quirks but overall they are less prone to annoying issues.
what about the 4 cylinder 320d engine, any good ? Sorry for the questions but I'm on the look out for a e90 for my mum I'm currently only looking at 325i or 330i as they seem pretty reliable but the 320d mpg figures are more appealing to her. |
09-13-2015, 04:32 PM | #11 |
10
Rep 442
This is very interesting! Just out of curiosity iv had my pre lci e92 330i n53 dct I have just ticked over 71500m I change my oil every year and iv been driving 50-55 miles a day since June would this help stop the carbon oil deposits in the engine? Cheers
Last edited by afalton; 09-13-2015 at 04:33 PM.. Reason: Forgot to put in a bit more |
09-14-2015, 03:45 AM | #12 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Great post as always Steve...if a little scary in the content department!
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
09-14-2015, 03:49 AM | #13 | |
130
Rep 1,534
[QUOTE=Mark e90;18573693]
09-14-2015, 04:20 PM | #15 | |||
283
Rep 2,796
[QUOTE=richk84;18575892] Quote:
For people buying 320d's for economy only to do short journeys who want to see fuel economy as a bonus things like DPF issues could well haunt the car and the owners finances and paitence I personally wouldn't entertain a diesel for short durarion journeys as the use doesn't sit comfortably with the cars longterm durability From start to finish you can polish the job off on around 6.8 hours you've also got to do a rocker cover gasket change when doing the guides plus as they plastic guides disintegrate you have to do an oil service too to get any remanence of plastic that could be swimming in the oil out of the sump area we chose to let the oil drain for hours just to give everything a fighting chance which might sound a tad OTT but it can't do harm but might do some good |
09-14-2015, 04:33 PM | #16 | |
283
Rep 2,796
There's nothing wrong with a 320d they are in the right hands for the right user the best option offering great fuel economy and frugal running costs the sting in the tail though are those possible DPF, turbo costs when they fail or reach a point where they are no longer serviceable If your mums going town work or short journeys then looking at a petrol might be the smarter long term move though the headline figures don't look as attractive |
09-14-2015, 04:35 PM | #17 |
448
Rep 3,312
Some interesting stuff Steve.
Oh I miss my M5. That engine is a true stunner (when working lol). I had about 10k of warranty work within the first 6 months of ownership LOL. But with a custom exhaust I'd never heard anything nicer to me when going through the Queensway tunnel in Birmingham.
E92 335i / M3 Hybrid - The Build
09-14-2015, 05:30 PM | #19 | ||
111
Rep 716
[QUOTE=old grey steve]
09-14-2015, 08:26 PM | #20 |
Rep 90
Cheers Steve...as you can see I've an ex-armed copper car...I will be taking it to the motorway to regenerate the DPF right now!😇
09-15-2015, 10:19 AM | #21 |
28
Rep 901
oh the 320d and turbo issue... all to real for me right now!
Pre LCI Monaco Blue e90, iDrive, 18" 220M reps, M3 Front Bumper, LCI headlights, Darklines, Eibach Pro Kit [Build Thread]
ICE: DLS R4s, Gladen HG-201BMW-3, Alpine PDX 4.100 |
09-15-2015, 01:04 PM | #22 |
15
Rep 105
Just joined and have read through this and many of your "visit" threads - will be paying a visit regardless of the 80 or so miles you are from me! plus...it's my old stomping ground!
