Please Help... cut wires.
09-08-2015, 02:20 PM | #1 |
Rep 5
Im New in this forum, pls take it easy on my. My 2011 3' E93 LCI BMW M3. Type Code: DX93 was involved in a rear end collision. I decided to fix it myself. i got the bumper cover, replace air bag, everything was fine until, i discovered 4 cables that were cut, and I dont know where they belong to. After the accident, the convertible top wont open. fuses are ok, solenoids ok, ctm working fine, since i just got it new from dealer. The cut cables are in the rear right quarter panel, next to the speed sensor plugs. I track the cables, they run to the CTM, then to the CAS and Fuse-box. they might belong to a sensor or missing module. If you guys can help ill be thankful. Im attaching some pictures so you guys can see what i am talking about. thanks.
09-09-2015, 04:34 AM | #2 |
458
Rep 2,754
you better to read car using diagnostics, there should be error codes in relation to unavailable ECU, because green/orange is body CAN bus colors
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
09-09-2015, 11:18 AM | #3 | |
Rep 5
thank you ptpending,
D904 CAS: K-CAN line fault E444 SMFA: K-CAN line fault e484 SMBF: K-CAN line fault any idea? |
09-10-2015, 07:30 AM | #4 |
458
Rep 2,754
do you have rheingold software and d-can cable
start test and see via ECU tree map what ECU is unavailable CAS is located near driver knee, SMFA i SMBF is seat modules
09-10-2015, 07:45 AM | #5 |
458
Rep 2,754
according wire color it is RDC ecu
please check it's presence via RDC ECU is A85
09-10-2015, 02:49 PM | #6 | |
Rep 5
http://www.m3post.com/forums/showthread.php?t=327609 this is the part number: http://www.realoem.com/bmw/enUS/show...diagId=36_1435 |
09-10-2015, 03:49 PM | #7 |
Rep 5
btw, i dont have rheingold software and d-can cable, but ill be more than glad to get it, do you know where to get it? is it expensive?
09-10-2015, 04:36 PM | #8 |
458
Rep 2,754
oh, forgot this is e93, it is under rear seat backrest
rheingold software on torrents or bimmerfest, inpa d-can cable on ebay
Tags |
convertible roof, electrical help, sensors, wire, wire harness |
