335ix 2008 30ff fault code HELP!
09-07-2015, 05:40 AM | #1 |
Rep 16
Hello everyone!
I am having this issue like many of us with the N54 have or have had. 30ff Low Boost Pressure and the car feels like it has a N/A Engine and have lost power. I have spent a crazy amount of time reading the experiences of people that have had this problem and the possible causes and of course possible fixes. This 30ff code is thrown whenever i go Wide Open Throttle and are around 4500rpm. A notification sound can be heard and a yellow half check Engine light can be seen on the dash, however this Engine light is cleared when you restart the car but the code 30ff can still be read. I have had the car at our local BMW Dealer two times the past weeks where they have tested if there is eny leaks, but so far they have not found anything and they said that the turbos where ok. So my question to you guys is what could the problem be if there are no leaks in the pipes from the Turbo to the intakemanifold? and as far as i know the vacum system is working as it should, brakes works fine, exhaust flapper is working and i can feel a small vacum from the vacum canisters if i pull out the hose when the engine is running. And from what i can tell there are no wastegate rattles, the engine sounds fine and runs well in eny other conditions, as far as boost goes the highest boost reading currently is 3psi but thats from the Torque App and i Think that app cant read boost correctly on an N54. This leaves me to Think that my wastegates are 100% open at all times or that i have a bad pressure converter or wastgate solenoid if i am not messing up the names... What do you guys Think this could be? BMW blames the Dual Cone Intake... but the airfilters cant mess with the boost right? It would also be interesting to hear you guys experience with this problem, if you have had this 30ff code, what fixed your problem? Thanks so much for taking your time helping out, much apprechiated! |
09-07-2015, 09:32 AM | #2 |
Rep 50
Drives: 2008 335xi
I had a similar problem after putting back together following walnut blasting intake valves. No boost at all, engine malfunction indication on the dash. After taking everything apart again I found a snapped vacuum line connector right behind the oil filter housing, below the fuel injector rail. Spliced in a piece of rubber tube and back in business. Hard to believe something so simple can cause so much grief.
GoRomeo971.00 |
09-08-2015, 07:11 PM | #4 | |
681
Rep 3,696
1) Current mileage on the car? 2) Are you running any tunes (jb4/cobb/etc...) and the setting 3) All mods? 4) Any recent work done to the car prior to your first instance of the issue? 5) Mileage at when you had carbon blasting done (if ever)? 6) Mileage at when you had the spark plugs changed? 7) Mileage at when you had the coils changed (if ever)? 8) anything else notable that can help us diag? my vote is you have never had the car carbon blasted and your cyl 5 or 6 is very clogged up, but the wrinkle here is you don't have any misfire codes. next guess is you have a vacuum/boost leak (yes someone tested it... but they missed something). 30FF is a limp mode for the car where u will make no boost. so your observations are correct, the car is doing what it is suppose to do when it gets a 30ff. the problem is 30ff by itself is a useless code kinda like having a fire alarm going off (you know there is fire somewhere... just don't know where it is) |
09-09-2015, 03:06 AM | #5 |
Rep 16
Thanks for replying to my thread guys!
Yeah i still feel like its vacum related, and if the airfilters would restrict to much air wouldent the car run bad in other conditions? - Sparkplugs where changed 4000 miles ago so pretty new. - car has 68.000 miles. - Only recent work was changing the waterpump and thremostat. - Dont know if or when the last walnutblasting was done. - Mods - Dual cone intake filters and JB4 But JB4 is completly turned off so it should not interfere with the car. Problem happens with and without the JB4 tune. If i have clogged cylinders wouldent i get misfires then? and at my miles its probobly not that bad of carbon buildup or am i wrong? No other codes besides 30ff code. Thanks for your answers! |
09-09-2015, 07:19 AM | #6 | |
Rep 16
I know some people are getting boost but just after they get the 30ff code the boost is cut (boost controll shut of) but my car has no boost at all. Atleast it feels like no boost. |
09-09-2015, 07:22 AM | #7 |
Rep 16
09-09-2015, 01:25 PM | #8 | |
681
Rep 3,696
Waterpump as recent work might indicate that someone might have put something back wrong or possibly hit/damaged something along the way. I have no proof or any useful guidance, i just have a gut feeling that it's a boost/vacuum or Charge Pipe leaking issue, maybe FMIC hoses leaking? Since you say it happens all the time like you are running as a N/A motor... it can't really be anything other than that (maybe it's a bad turbo wastegate which has failed open - the default state). |
09-09-2015, 05:32 PM | #10 |
Rep 41
07 335xi here with JB4, 3" catless dp's, charge pipe, and fmic just installed throwing the 30FF code now. Upgrades all done at once except the JB4. Very interested to know what happened here.
09-11-2015, 07:50 AM | #11 | |
Rep 16
They must have missed something! If they cant find anything i will definently look into wallnutblasting. Thanks for your help man! |
09-11-2015, 08:02 AM | #12 |
Rep 16
I visually cant see damadge on the vacum hoses so it can definently be a defective pressure converter (boost solenoid)
Thing is i dont really know what BMW have tested but i think i need to ask them what exacly they have tested, guessing they are as Clueless as me... |
09-11-2015, 08:08 AM | #13 | |
Rep 16
I have also heard of people that have found that the new downpipes sometimes interfered with the wastegate So try checking that. Good Luck |
09-14-2015, 12:17 PM | #14 | |
681
Rep 3,696
09-15-2015, 05:44 AM | #15 | |
Rep 16
I have stock downpipes and yeah i have also considered that some setting might be wrong on the JB4, BUT i have the JB4 set to the bypass map 0 (stock) The JB4 should not be interfering with the cars values then right? or am i wrong? |
09-15-2015, 09:40 AM | #16 |
681
Rep 3,696
You are correct... if on Map 0 and you have cat's... then you have nullified my concerns.
09-15-2015, 12:04 PM | #17 | |
Rep 41
09-15-2015, 12:12 PM | #18 | |
681
Rep 3,696
I think the OEM vaccum lines are expensive... but aftermarket is cheaper but the wrong diameter??? so i think the stock is 3 mm and after market is 3.5 mm in diameter or something like that. You should be able to follow and chance most of the vaccum lines (just measure and cut to length one by one). If the oem vacuum lines don't come off easily... don't force them off cuz you will break the plastic nipples they are stuck onto. What you want to do is slice the old vaccum line on the nipple and peel it off gently... then install the new vaccum line. The ones WAYYYYY in the back on the turbos are almost impossible to reach. |
09-20-2015, 04:25 PM | #19 | |
Rep 41
09-20-2015, 10:21 PM | #20 | |
681
Rep 3,696
09-22-2015, 09:26 PM | #21 | |
Rep 41
Now about this waste gate rattle... |
09-22-2015, 10:24 PM | #22 |
681
Rep 3,696
30FF is such a b1tch to diag on its own, you need other codes along with it to help guide you to something. 30FF is just safe mode for the car without telling u any supporting details
