Gearbox oil change (335D)- West Midlands
09-03-2015, 09:59 AM | #1 |
19
Rep 129
Hi All,
I know A1BN can do this, but Herfordshire is little far for me. Can anyone in the West Midlands do this? |
09-03-2015, 10:27 AM | #2 | |
160
Rep 2,399
But I know a company in Cannock who do it for £250 cash supply and fit using genuine sump and oil if only I found them before I had my work done google them cant remember what they called autobox specialists or something |
09-03-2015, 10:35 AM | #3 |
115
Rep 316
Drives: 2018 F31 340i Shadowline Ed
Everything so far I've had done my car I went to BM Automotive too. Can't really fault them to be honest.
09-03-2015, 10:37 AM | #4 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Why not DIY it? It's so straightforward (plenty of guides on YouTube). And as it's not a BMW serviceable item it's of no consequence that it doesn't show on your service record...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
09-03-2015, 10:46 AM | #5 |
19
Rep 129
Hi Raj and 2die4, thanks for the prompt responses.
BM Automotive Solution quoted me £495 for supply and fit. http://www.vmtp-midlands.co.uk/workshop/ in Cannock have quoted me £245 for supply and fit. Is it the same company you were referring to? One more thing, Raj - Have you got the link for the kit from ECP? Last edited by IceMan007; 09-03-2015 at 10:57 AM.. |
09-03-2015, 10:54 AM | #6 |
283
Rep 2,796
The instructions are within the ZF box so to be fair if followed most garages could carry out the process, the issue comes to light re monitoring the amount of oil going in, allowing time for the fluid to circulate and the time taken to drive the car on a ramp in all gears to allow the fluid to circulate.
But where most will fall flat is post work re setting the adaptations on the gear box and engine ECU, which we do so that everything goes into a re learn procedure and we're not talking about the key in the slot and holding the throttle for 30 seconds thing but a proper diagnostic entered full re set, which works wonders as it allows the gear box the engine ECU to work together and re learn your driving style from scratch, this is the icing on the cake and since we've been doing it as part of the service it makes a difference Last edited by old grey steve; 09-03-2015 at 11:09 AM.. |
09-03-2015, 12:00 PM | #7 |
23
Rep 523
09-03-2015, 12:18 PM | #8 |
616
Rep 3,194
Sorry I assumed this was MT not AT when I suggested DIY...
09-04-2015, 06:48 AM | #9 | |
160
Rep 2,399
yes they are the company I would of used if I found them earlier. cant beat that price tbh and the I will dig the part number out at Euro although my SUMP was wrong size so be wary. best bet use VMTP |
09-04-2015, 09:14 AM | #10 | |
283
Rep 2,796
Petrol 50411058K Diesel 50411059K Cross reference your reg with the above should be OK |
09-04-2015, 09:40 AM | #11 |
19
Rep 129
Thanks Steve and Raj, quick question - What colour is the oil when it comes out? Is it black or just dark?
Was talking to VMTP today, and their words were "if it comes out black then you're in trouble as something has burnt it and chances are, the tranny is knackered". I haven't checked mine yet (booked for next Friday) and don't have a single problem with the gearbox (other than holding onto gears a little longer than normal and very occasionally jerky) but all the pictures on the other threads look as though the oil is black....and none of the posters have had knackered gearboxes... VMTP have said that it is impossible to get all of the oil out - approx 50% (after leaving it to drain) as the rest will be inside in the gearing mechanism. If the gearbox oil change requires approx 6 litres, then they only change 3?? He then started "bashing" others for "talking crap" as far as they were concerned, it is impossible (to get 100% of the oil out). Confused.com Last edited by IceMan007; 09-04-2015 at 09:46 AM.. |
09-04-2015, 09:49 AM | #12 | ||
160
Rep 2,399
09-04-2015, 09:59 AM | #13 | |
283
Rep 2,796
Some smell more than others and that's to do with many things but if they smell to much chances are something's happening inside usually the fluid makes a real difference if the issues gone too far then you could be looking at a failing mechatronics plate assembly and the 7 or so solenoids that control what happens |
09-04-2015, 02:01 PM | #14 | |
13347
Rep 7,484
09-04-2015, 02:05 PM | #15 | ||
13347
Rep 7,484
09-05-2015, 03:05 AM | #16 | |
283
Rep 2,796
But a nice thought |
09-05-2015, 03:52 AM | #17 |
Rep 83
Is this a preventative measure or are you doing it because you can feel an issue?
I thought the oil on an auto didn't really need changing like a manual does. Although it would make sense oil doesn't last for ever. Just want to take note if there is a recommended mileage this should be done? Cheers
___________________________
2006 330i E90 2001 330ci E46 |
09-05-2015, 04:14 AM | #18 | |
283
Rep 2,796
Moving forward its recommended by ZF to change the sump/fluid every 100K's or so, its good practice to change the sump/filter and oil then re set the required adaptations as the car would of adapted to driving with X amount of fluid and its condition new gear box fluid and an new sump/filter will allow things to flow a hell of a lot easier and will improve to a degree drivability, and fuel economy to a degree due to less drag. When you see the colour and smell the fluid that comes out you'd question the term "lifetime" as stated by BMW We opted not to go down this route with yours and Alex's cars while they were here along with other service needs purely based on the fact that there more important things on the agenda, but going forward a worth while exercise to do the gear box etc |
09-05-2015, 04:29 AM | #19 |
1073
Rep 1,957
Drives: E90 M3 LCI Jerez Black
I think ZF state between 50-70k miles for the oil, depending on how you drive.
IIRC from reading the ZF technical notes. |
09-05-2015, 04:38 AM | #21 |
283
Rep 2,796
100K= kilometres in ZF German speak, therefore on paper 62.000 miles, I done mine at 60.000 miles it was dirty though like yours zero leaks we done a525d yesterday more oil out of the sump than in, you could of had a bath with the amount of oil on the sump pan and sump pan tray.
09-05-2015, 04:46 AM | #22 |
Rep 83
Ah no worries will do it at next service or something drives perfectly at the moment just needs an I drive
