ABS sensor after dealer visit - happened twice
08-30-2015, 07:04 AM | #1 |
12
Rep 153
I had all wheels replaced last November by dealer under warranty - hooray. Then when I set off the very next day the ABS sensor light came on. Ended up paying dealer to replace one sensor cable. A week later same warning came up and had another cable replaced by local garage for half price of dealer.
NOW, I just had the oil changed at dealer and like before, the next time I used the car, the ABS light has come back on. Can it really be a coincidence that each time I take it to the dealer the day after the ABS lights come on?? After they removed all wheels and replaced them there is a good chance they disturbed the ABS cables, but not with an oil change. They did do a vehicle inspection when the oil change was done, perhaps someone tugged a cable? Or perhaps the dealer is doing it deliberately? Doesn't seem plausible but then again, the car was completely fine before the dealer touched it and the lights only came on the day after being to the dealer. That is just too much of a coincidence. Anyone had similar or want to comment?
Pro-Nav, Pro sound, comfort, most everything.
08-30-2015, 12:10 PM | #3 |
12
Rep 153
Last time it was two different sensors. Do not know yet this time as not had it diagnosed yet. Thanks for the reply.
08-30-2015, 06:29 PM | #6 |
12
Rep 277
I'm not sure how much you are paying for all these sensors, but just change it yourself would be my advice. It is literally remove the wheel, then one allen bolt and a plug. I replaced mine recently with a branded non oem sensor for £23 + 10 minutes of my time.
08-31-2015, 03:48 AM | #7 |
283
Rep 2,796
Curiosity that's all if the cars knocking out sensors you'd have to ask a question or two, from are the sensors good quality, have they been damaged when fitting to is there actually something else going on.
Namely if we are talking rear wheel speed sensors we need to get the driveshafts looked at for contamination signs as if these have swollen they distroy any sensor replaced and the signs will be how the sensors removed have worn. |
08-31-2015, 11:24 AM | #8 |
12
Rep 153
I will find out from diagnosis tomorrow. The replaced sensors were BMW originals and they were replaced with BMW parts. The replaced sensor cable that I kept, which I think was from the rear, shows no wear at all. And there is no apparent damage to the cable, not even a tiny nick. I hope to get it into an iddy tomorrow as I am taking the car to Germany on Wednesday, which is the only reason I had the oil change done. Car has only done 53,000 and last sensor went at 51,500 miles (as I said, also the day after it was in the main dealers). I am not using car much, so only 1500 miles in a year or so. Maybe it is a battery problem? Seen that mentioned by others on the forum. Thanks for your reply.
08-31-2015, 11:49 AM | #9 | |
283
Rep 2,796
You mention power re battery and yes if you've got a battery issue it can bring on a DSC light and again diagnosis re looking for power issues within the DSC and exhausted battery will come to light in a diagnosis test. But if you've had previous historic issues re sensors it pays to get the car diagnosed and checked thoroughly, the other thing on these that can be DSC related could be due to several issues known within the DSC, but as you say only real proper way forward is get an Indy to stand by the car and find out what's happening. Last edited by old grey steve; 08-31-2015 at 12:03 PM.. |
09-06-2015, 11:47 AM | #10 |
12
Rep 153
Okay. So turns out to be rear and sensor cable. Very odd that it happened last time the dealer had the car. Someone said something about the wheels being spun. Suggested that if ignition\engine is on and wheels are spun then you can get fault. As dealer also had car on ramp to do vehicle check it is quite possible the spun the wheels as they did report on tyre trend! Very expensive free vehicle test!!
