MHD Flasher
08-27-2015, 05:53 AM | #1 |
283
Rep 2,343
MHD Flasher
Hi,
does anyone know the cost of the monitoring module on MHD flasher? Anyone using the maps? Thanks
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
08-27-2015, 05:57 AM | #2 |
283
Rep 2,343
Managed to find it.
$69 I have the back end flash version. $79, I think it was.
08-29-2015, 01:19 PM | #3 |
16
Rep 212
Drives: E92 335i & E93 335i DCT
I'd skip the monitoring module personally, seems crazy expensive for what it does. I use MHD for the flashing but the JB4 app for the monitoring and logging.
I have an old android phone I keep in the car for it, seems to work a treat.
E93 335i DCT M-Sport
Turbo Dynamics Stage 2+ Hybrid turbos - Evolve FMIC - VRSF catless DPs - Remus Race exhaust - Injen CAI - VRSF CP & HKS BOV - Quaife LSD - Gladen 120.4 DSP kit - CIC to NBT Upgrade - JB4 G5 w/ race flash - Ohlins R&T suspension - next mod: go faster stripe. |
08-29-2015, 01:20 PM | #4 |
16
Rep 212
And I'm using the JB4 backend pump flash map, not the MHD maps.
08-30-2015, 04:49 AM | #5 |
Rep 208
I use the MHD and the JB4 app the same as AndyN. I usually use the pump flash and have just started switchin to the Race map for w'end fun 😉. It's way to use and pretty straight forward to install. The maps are nice and smooth & driveable but you do need to log and check things regularly to be on the safe side.
08-31-2015, 05:16 PM | #6 |
283
Rep 2,343
Cheers lads,
so basically I have been using a JB4 for probably a year now. I've been running the Race flash mostly and the E85 flash at the moment modified for the Euro cars and DCT box. I use E85 when adding ethanol in conjunction with meth and running at drag strips. I contacted Ken A. to see about getting a Wedge flash to take the car to another level but he said I needed the monitoring module in MHD to log and do tuning. JB4 logs aren't good enough apparently. Maybe it's just because of the flash/piggyback wars? It may be that it was assumed I was asking for a flash tune and not a BEF. Anyway my car runs really well on the current back end flashes. 20lbs boost, perfect timing on all 6 cylinders. I'm not sure how much further any flash could take the car to be honest. Plus some comments say wedge flashes are a bit harsh on the car and risky. Pushing hardware to the limits. The thing with the MHD monitoring is that I don't think the module can run without the JB4 being turned off or the wiring harness modified (as per Terry's post on JB4 for monitoring only). I use my JB4 for logging and real time gauges with the mobile app. As I have my JB4 running my boost and meth flow, I'm pretty happy with my setup. It's really just if things like Vanos settings and other things I don't fully understand can improve my car's performance.
08-31-2015, 05:19 PM | #7 | |
215
Rep 1,818
for most street cars that's more than we really need... but when has that stopped any of us? |
08-31-2015, 07:05 PM | #8 | |
283
Rep 2,343
It's more that it may be possible to improve performance through tuning other factors available in the DME with a flash which general back end flashes don't do as well as they could.
09-01-2015, 09:59 AM | #9 | |
215
Rep 1,818
09-01-2015, 06:56 PM | #10 |
283
Rep 2,343
09-01-2015, 06:57 PM | #11 |
215
Rep 1,818
09-03-2015, 10:26 AM | #12 | |
283
Rep 2,343
you'll want to head over to N54Tech Look for the thread in the N54 section. Have a good read of this thread: "Custom BMS flashes for your Euro-spec N54" That shows you how to mod a flash file in tuner pro. Download tuner pro for free. European cars have slightly different tables for tuning to US models. Download the flash file and xdf from this thread: "Sticky: *********** N54 free flash tuning" Many of the experts also have their own XDFs with more tables defined which you can search for on the forum. Have fun. There's so much in there. I don't know 95% of it Or I know what it does but I dare not change it in case something goes bang. Haha.
09-03-2015, 10:28 AM | #13 |
215
Rep 1,818
