Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Rollover protection fault - Airbag and seatbelt warning lights on as well.
      08-26-2015, 03:31 PM   #1
The Londoner
15
Drives: M4 Comp
The other day my car decided to throw up an Airbag and passenger seatbelt warning on the dash. Had the car scanned pretty much immediately and the specific error code is.... 9402 - Rollover Controller Internal Fault.
The warning and error popped up when the car was stationary, however the car had been jacked up and had the rear wheel off about 2 miles / 20mins beforehand.
Clearing the fault has been attempted by a non-BMW dealer tool but no luck, error will not clear and warnings on the dash are still there.
Any idea what might have caused this fault or how to clear/fix it??
      08-26-2015, 04:12 PM   #2
Aragorn30d
175
Drives: E90 330d
"internal fault" suggests that theres an actual issue with the rollover controller, rather than an accidental deployment.
You'll probably need to replace the controller.
See this thread, post 16 onwards:
http://www.bimmerfest.com/forums/sho...d.php?t=829808
      08-27-2015, 02:12 AM   #3
The Londoner
15
Drives: M4 Comp
Replace the controller.. Wow.. It went kaput just like that?
Are these BMWs the most unreliable cars in the world? I've owned and driven cars for over 20 years and I've never read so many first hand experiences of random component faults, engine problems and recalls/service bulletins....
Nox sensors, injectors, hpfp, coilpacks, wheel plates, knocking noises from various parts of the engine, disa valves, vanos whatevers, etc etc etc.
Beginning to think the risks of owning this car outweighs the enjoyment.
      08-27-2015, 06:01 AM   #4
Aragorn30d
175
Drives: E90 330d
You can probably point the blame at lead-free solder :P
      10-11-2015, 10:22 AM   #5
The Londoner
15
Drives: M4 Comp
Update:
Controller replaced, problem solved.
      03-01-2016, 05:03 PM   #6
gerbilunit
Drives: BMW 2009 e93
Originally Posted by The Londoner View Post
Update:
how much did this cost and how easy was it to replace?
      03-02-2016, 12:33 AM   #7
The Londoner
15
Drives: M4 Comp
Update:
The part was ridiculously expensive for a sensor... Something like £400 I think. Labour not much different. I had some other work done too, but basically it was a £800 job roughly. My warranty covered it fortunately.
      10-30-2018, 01:22 AM   #8
casperarizona
Drives: 2009 335i E93
Did you need the roll over control Module programmed?
Did you need the roll over control Module programmed? Or was it Plug and Play? I in the same spot as you were! Thank You for your help
