i have a 2009 320 coupe m sport highline
08-25-2015, 03:20 AM | #1 |
Rep 9
i have the above and im wondering can i or what do i have to do to change the rear bumper to have the twin exit exhaust on the back like the 330 model?
08-25-2015, 04:11 AM | #2 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
I think you mean the 335i (the 330i has a single outlet like yours). Do a search mate, it's been covered quite a few times...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
08-25-2015, 04:32 AM | #3 |
175
Rep 1,596
330's have a single box with twin pipes:
http://www.hf.rs/share/bmw/mrear.jpg 335's have two boxes with single pipes: http://www.insideperformance.de/imag...or_carbon2.jpg If its a 320d you have, the 330d system will fit right on if you get the whole system. The petrol models are a bit different as the front part of the 6 cyl exhaust has two pipes, however the rear box can probably be fitted with a sleeve clamp or reducer. If you want a dual box system like the 335's use, then you'll need a new boot floor amongst other things. |
