wheel offset advice please
08-23-2015, 12:47 PM | #2 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
08-24-2015, 07:34 PM | #5 |
Photographer
412
Rep 2,643
No, no you're not.
I've got 255/35 on a 9.5 and you can't even tell. 9.5" is well within the recommended fitment for a 255 tyre. For reference, I have a 9.5 ET45 with a 255/35/18, and there's easily 10mm of space before you even need to start thinking of arch work. About 20mm until flush with the arch. Also, 255mm is 10", so it really comes down to how close to true size the tyre brand is, can run about an inch in variation from what I've seen, some are meatier with squarer sidewalls, others thinner with a more rounded one. |
