Do my headlights need UV protection?
08-21-2015, 07:11 PM | #1 |
66
Rep 262
I just had my headlights sanded/polished at a professional detailer (along with interior detail and engine compartment detail). They did a great job, and the interior, engine, and headlights look brand new on a car that has almost 100k on it.
I talked to the girl at the desk and asked if they apply UV protection. She checked with the boss and was told they do not. He said the UV protection was inherent in the plastic. He stated they will oxidize if you only polish them, but they sand and polish them. Is this B.S.? Is there a certain sealant i can/should put on the lenses, or just let it ride? Im not super picky about my car (my bumper looks like hell with a lot of chips), but i dont want my lights to oxidize quickly. Thanks in advance. |
08-23-2015, 01:32 AM | #2 | |
31
Rep 547
When you break the process into its basic elements....both sanding and polishing is about removing materials. Sanding does it at a greater rate. If UV protection was inherent in the plastic then why would it ever oxidize in the first place. I am sure someone will correct me if I am wrong. I would seal the lens with a good sealant or a coating.
What is absolute control???? Having the means and the abilities to exercise it at will but....chooses not to.
08-23-2015, 10:21 PM | #3 |
Gateropode
329
Rep 2,848
If the plastic was sanded, it needs to be resealed. They will oxidize, and rather quickly at that. I am actually baffled that a serious business would even propose sanding the headlight and not apply sealant, this is nonsensical.
You can buy yourself some sealant and apply it with a sponge, it's not very hard, the chemical itself is somewhat pricey, but I were you I'd insist they do it, you paid for refreshing your healights, not for time offset damages to your headlights oO |
08-23-2015, 10:58 PM | #4 | |
66
Rep 262
Do you have a sealant you recommend? Can i use a regular paint sealant on the headlights? I use wetfire black-diamond on my paint....not sure if that would cloud the polycarbonate? I may call the shop and ask if they warranty cloudy lenses. |
08-24-2015, 08:06 PM | #5 |
Completely obsessed with detailing
299
Rep 15,442
Drives: E90 SG 330i, white Scion tC
Your sealant will work fine. Just remember to always have some on your headlights to prevent the hazing and yellowing.
The one is made for paint because it has parts of it that make it shiny. Generally, sealants all work the same and differ in durability and how shiny they are. There are trade offs. For headlights, you don't care how shiny it looks. I use one called Rejex. You can find it OTC, and it lasts about 6 months before I clean it off to reapply. What your detailer said... sounds a little silly to me. Sanding is just a harsher form of polishing. Headlights and other things DO have inherent UV protection put on them at the factory. Abrasives remove it, so you will need to continuously reseal the headlights. |
08-26-2015, 10:39 AM | #6 |
74
Rep 322
Opti-Lens has been the best product I've used, its rather pricey and only sold online. If you are looking for a quick and dirty, Blue Magic headlight sealer is OTC and holds up for several months.
MHD Stage 1+ FMIC // VRSF 5" stepped// StopTech x-drilled Centric Posi-Quiet Ceramic Pads // Wiesslicht AE's // OEM Blacklines // Matte Kidneys // MonoChrome emblems.....
08-26-2015, 12:27 PM | #7 |
360
Rep 5,052
The unfortunate truth is that once the OEM UV protection has worn off, your headlights will require regular maintenance in order to keep them looking good.
Depending in on the environment you live in, your newly restored headlights may begin to fade again in as little as a week or two without any UV protection. I would recommend applying a quality wax or paint sealant if you have any on hand. Something like BlackFire Wet Diamond. I would recommend applying a traditional wax or sealant to your headlights at least every month just to keep a healthy layer of protection on them... it takes 2 minutes, so it isn't a real chore. If you wanted someone that was a bit more maintenance free, I would recommend looking into a plastic coating that is more durable than a traditional wax or sealant. Some good options would be 22ple VR1 or CarPro DLUX. These silica based coatings will provide longer lasting protection. In the end, your headlights will certainly need to be restored again over time, however if you maintain them well, they should never get to the point where sanding is needed. Just a quick polish every 6-12 months as needed will keep them looking great. Other Resources Headlight Restoration Process by Todd Cooperider Let me know if you've got any other questions. Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com Last edited by Detailed Image; 08-31-2015 at 01:34 PM.. |
08-29-2015, 01:09 PM | #8 | |
66
Rep 262
I put some blackfire wet diamond on them. Ill try to re-apply every month and see what happens. |
