08-21-2015, 05:29 PM | #1 |
77
Rep 261
M235i (2015) 6MT throttle response
Wondering if anyone else is having this issue. I searched far and wide and only found a test drive on edmunds echoing my experience.
http://www.edmunds.com/bmw/2-series/...owertrain.html I recently switched from a 2001 330i 5MT to a M235i 6MT. On my old e46 when I stomp on the gas pedal I get an instant neck snap and can feel the engine pulling hard up to the redline. Everything is logical, lower gear pulls harder than higher gear. On the f22 when I stomp on the pedal there's usually a ~1sec hesitation while the ECU decides what to make of it, even though when I stomp on the pedal it means I want thrust. And it also creates a strange sensation in lower gears where it kinds of meanders along, then in 3 or 4th some light bulb goes off and gives me gobs of thrust. I expect this sort of shenanigans from an AT, not a MT. The dealer service dept knows about that and suggested I switch to sport+ and turn off DSC. I did that but the hesitation is still there. It's quite baffling. |
08-21-2015, 06:01 PM | #2 | |
Rep 13
08-21-2015, 06:11 PM | #3 |
77
Rep 261
I rather like the brake response on mine. Also the shifter feels pretty "crisp" whereas my old 330i felt "rubbery".
I agree, as do the service techs, that the problem lies with the throttle map. It's wonky. Their reasoning is that it's to prevent the drive train from getting torn apart from the torque. But I felt it's sort of nerfed the engine and I find I can't predict what the engine would do when I press the gas pedal this and that way. I can't believe people aren't complaining more about it, especially ones who have driven older BMWs with much more direct throttle response. |
08-21-2015, 06:24 PM | #4 |
Rep 13
People often complain about the unpredictability of a turbo charged engine. I always thought it is due to the turbo lag and the non-linearity of the turbo boost. But this problem apparently is not related to the turbo in a direct fashion. My M235i is with the dealership for seat leather replacement due to pre-matured wear on the seat bolsters. When I get it back, I will pay more attention to this problem. But I do not recall I experienced it before.
08-21-2015, 06:45 PM | #5 |
77
Rep 261
Well let me know if you do find anything. Dealer is no help, basically saying that's just the way it is. This is the only thing I don't like with this car vs my old one.
08-21-2015, 07:05 PM | #6 |
Kingslayer
411
Rep 1,479
My 08' 135i was the same way also 6MT. Personally I think it is some driveline preservation programming behind the scenes. If it's any conciliation my 13' 328i x-drive although it's a 8AT feels the same way at times. Last year at a BMW Driving event I spoke to one of the instructors about it - he said unequivocally it was the DSC that causes it. Try turning DSC all the way off and see how it feels.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i Current Cars: 2019' X3, 2021' M3 Comp |
08-21-2015, 07:37 PM | #7 |
157
Rep 387
I came from an E46 5-speed manual and Yes, I noticed the throttle response lag on the F22 as well.
My e46 had drive-by-cable which was as responsive as it could possibility get. I sure miss that feeling. It made rapid downshift rev-matching a breeze. |
08-21-2015, 08:08 PM | #8 |
5255
Rep 5,874
This is nothing new in BMWs after E46, specifically the turbo'd models. You're used to the naturally aspirated GO and for some reason they changed calibrations that include some tip-in delay on later cars. I traded my wife's X1 28i in for my M235i and that X1 had the absolute worst throttle delay. It was downright dangerous. I do notice it just a smidge with my 235 (8sp auto) but it doesn't bother me other than I can't really burn rubber from a standstill unless I try out launch mode. It is interesting to me that you have a 6MT and are feeling this issue though.
Honestly the throttle off the line is pretty good on this car compared to other bimmers and even other brands (Golf R I'm looking at you). I also did the ultimate drive event and smashed the throttles in sport mode on a 428i and a 328d. Both of them had severe severe delay. On one instance from a stop the instructor was like, "floor it!" and I said "I did!!" We laughed at the absurdity of the delay but it was pretty lame. I'm just glad my 235i is nowhere even close to as bad as some of these cars. |
08-21-2015, 09:35 PM | #9 |
90
Rep 351
Ehh...I'm going to partially disagree. granted, I haven't spoken to any engine or throttle response gurus....but...
I believe the lag IS turbo lag. why? when going WOT at low rpm (1.5-2k) there is the mentioned 1 sec delay. At higher rpms (3.5-4.5k) there is no lag. if the issue was throttle mapping it would be present at all engine rpm ranges, no? |
08-21-2015, 09:48 PM | #10 | |
312
Rep 818
If you want to see how linear our engines are, go drive an STi. Those things are a freaking dog under 3,000 RPM. Be prepared to hold on at 3,000+ though because that turbo really kicks in.
Playing devils advocate a little, I think everyone here is a bit spoiled with BMW.. especially since it seems most of us came from E46s (myself included; we also did EXACTLY what BMW wanted us do with the F22). We're all used to the insanely linear power delivery with basically zero turbo lag compared to the competition. Quote:
08-22-2015, 03:27 AM | #11 |
262
Rep 1,091
I dare say all turbo BMW models have the throttle response (lag, tip, tip-in - those are names used at nauseum in so many threads on the F10 board of the other forum) problem - and even if some people claimed it went away after software upgrade, it never did in my 528xi. It is also present in my current M235i (and on my R, for that matter) - but I just learned how to live with it:
- when moving from a stand-still, or just accelerating moderately from cruising at speed of up to some 80 km/h, never - and I mean it: NEVER - floor the pedal all the way in an instant to WOT; otherwise the problem with rear its ugly head more often than not. Instead, stomp on it firmly but somewhat gradually; no more 1-2 seconds of the engine doing nothing! Try it out. Of course, in Sport mode the rpm never drops below ca 2000, so the throttle is much less prone of behaving on me like this - but it can happen, too. So I extended this gradual throttle opening technique onto higher revs, too - this way it already became my second nature, and I don't perceive it as a problem any more... The logic is that - when you want to accelerate really aggressively and time matters (like when you want to avoid a potential collision with oncoming vehicle) - the time you lose by not flooring the pedal instantly is way shorter than what it might otherwise, when after flooring it and the engine actually reacting, you might have to wait even 2-3 seconds!
previous: 2003 E46 330i SMG
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD |
08-22-2015, 03:54 AM | #12 | |
Rep 13
08-22-2015, 08:35 AM | #13 |
659
Rep 891
Agree, turbo lag or caused by the ECU, there's definitely the slightest lag. On my M235i I'd say it's half a second or less. My previous car, a 2005 Mustang GT was also drive-by-wire, but that throttle response was instant in comparison. The throttle response between the two cars is a night and day difference.
Vehicles: 2021 Alpine White M2C 6MT; 2011 Kawasaki Z1000 (1/4 mile 10.3 seconds @ 129 mph - stock)
Previous: 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT; 2003 Mini Cooper R50 5MT |
08-22-2015, 10:29 PM | #14 |
106
Rep 1,428
My 2011 335 manual had this, very annoying, now I have a dct 135 and it does the same thing. I personally believe it's a perfect storm of drive by wire and the traction control, because its not so bad in sport mode with traction off. I started doing auto cross for fun and rode with an instructor, when exiting a corner he would yell throttle, throttle, but I was already on it. It is terribly annoying when trying to exit a turn at speed. If the e46 were a turbo motor I would have one. I'd leave these newer cars for the tech geeks.
08-23-2015, 12:55 AM | #15 |
1L
156
Rep 336
Let me play devil's advocate here for a moment...
Can I ask what driving mode you are in during you comparison test? I say this because, you may have to factor in the driving mode. How well do you drive a manual? I've had many folks who tells me they can drive a manual and find out later they burn through their clutch before hitting 50k miles. I tested your concern today during a long drive and I couldn't capture the issue you had. My previous 540i was very similar to throttle response to my M235i and it's very close to the torque power. I'm sorry but, I don't think your 01' 330i is a good throttle comparison to the M235i IMO. 215 lbs of torque does not come close to the M235's 330 lbs of torque. Instant neck snap is very hard to believe...real time throttle response, maybe. Maybe it's the drive by wire or turbo lag or maybe even the gearing (5MT vs 6MT), but I know one thing for sure about the M235, it is a character of its own and you cannot compare it to its predecessors. Just like you cannot compare the E46 to the E36 BMWs.
2015 Glacier Silver M235i/6MT
MP Front Splitter//MP CF Short Shifter//MP CF E-brake//MP LSD//Cold Weather package//Driver Assistance package//Oyster Dakota leather//Aluminum Hexagon trim//ECS Tuning Wheel Spacers//AutoPlus Rear Diffuser//HUD//Rexing DashCam//AutoID M Mirror Caps |
08-23-2015, 12:59 AM | #16 |
269
Rep 470
I did the free Ultimate Driving Experience autocross event and the instructor specifically mentioned something along the lines of "there are some people who complain about turbo lag in these cars. It's not turbo lag... the DSC is saving you from eating your mistakes"
2015 M235i | AW | 6MT | Tech | Heated Seat | Parking Assist | Fabspeed DP & Muffler Delete | Apex PS7s
1999 MX5 NB | Emerald Mica | 5MT | Sport Edition | Kosei K5Rs | Heated Rear Glass ig: @bee2ven |
08-23-2015, 01:56 AM | #17 | ||
262
Rep 1,091
08-23-2015, 11:41 AM | #18 |
Resident BMW Fanboy
259
Rep 866
I think this is due to the really soft engine/transmission mounts.
Current: '20 F82 M4cs SMB / '13 640i M-Sport Carbon Black
Past: F30 330xi Luxury Line / F22 M235i 6MT / E92 335i / E46 330ci / E36 328i 5MT |
08-23-2015, 11:51 AM | #19 |
262
Rep 1,091
Pardon me?
08-23-2015, 07:03 PM | #20 | ||||
77
Rep 261
I can and I will. If BMW intends this to be the car that gets E46 owners to switch over, they better make damn sure it's better in every way. Last edited by Y0tsuya; 08-23-2015 at 07:13 PM.. |
08-23-2015, 08:25 PM | #21 |
1L
156
Rep 336
Y0tsuya, the F22 is better than the E46 in almost every way. You bought the car didn't you? FYI, I am an E46 owner. BMW doesn't care if you drive an E46 or any other BMW. They're selling the M235i because they have a great product that driver enthusiasts love. Just my two cents...enjoy the car!
08-23-2015, 10:40 PM | #22 |
77
Rep 261
I did say this is the only thing I don't like about this car. But it's a biggie. I opened the topic to see if others are experiencing the same, and whether it can be fixed.
I bought it because I got tired of fixing my 330i with 190K on the odometer. This is one of the closest replacements I can find. I wish there was a MT M235i available for me to test drive at the local dealership but I have a better chance in seeing a unicorn. Though to be honest I probably would have bought the car anyway. Well word is BMW does care, a whole lot: http://www.caranddriver.com/reviews/...t-drive-review Or maybe they lied the same way they lied about the throttle having little to no lag. I'd enjoy it more with no lag. |
