N47 2008 320d engine capabilities
08-20-2015, 09:40 PM | #1 |
Lieutenant Coal Burner
161
Rep 1,639
Hey guys, I'm really curious about how much boost an n47 can handle. I heard Diesel engines are quite tough. Also I've seen a guy make a build using 2.3 bar for 200kw. The turbo I'm getting has a potential of 3 bar. Had anyone had any experience with boosting n47's here? I guess you could only assume if the engine hasn't been tested like this before.
08-21-2015, 09:40 AM | #5 |
46
Rep 891
08-21-2015, 01:33 PM | #6 |
175
Rep 1,596
GTB2260v from a 330d and some bigger injectors and corresponding mods will easily see you beyond 200kw:
I wouldnt bother with a hybrid. Hybrids typically involve fitting larger wheels into the turbo to get more airflow, but this also increases lag. The stock turbo is already big enough. What might be useful though is upgraded bearings to better handle the high boost pressures you'll be running. Bear in mind though, a 200kw 20d is going to be pretty laggy, because the larger turbo requires much more energy to spool it up, you end up moving the boost threshold further up the rev range. This is why higher power factory engines like the one used in the 123d or 335d use two turbos to help fill the hole. |
08-21-2015, 06:10 PM | #7 |
161
Rep 1,639
I've seen that video, am actually buying the turbo off him, turbo comes a hybrid. Also have spoken to him about more boost and he said you will need more flow that 535d injectors. Also have seen a 120d recently diving with 3 bar, I wonder how long that engine wil last though.
08-21-2015, 06:21 PM | #8 |
161
Rep 1,639
Don't know much about turbos, this one is costing me $1000 aud only so it's a pretty good price, hybridised by the guy who I'm getting it off. He also shed one of these in his black e90 vid ^^^
