F30 alloys on E93 tyre pressures?
08-19-2015, 12:14 PM | #1 |
30
Rep 210
Having just changed the alloys and tyre's on my 2011 E93 330d to the F30 19" 403s running 225/40/19 and 255/35/19 Goodyear RFT anyone got any idea as to what the tyre pressures should be?
08-20-2015, 04:22 PM | #6 |
30
Rep 210
As I have just purchased them complete with new Goodyear RFTs I'm not really looking to purchase new tyres for them, there is no rubbing and I'm using with 12mm spacers on front and 15mm on rear which is actually only 7mm as offset is 8mm different to begin with. According to the sticker on the door shut 225/35/19 is 2.8 bar (40.6psi) and 255/30/19 3.3 bar (48psi). With higher profile should the pressure be higher or lower?
08-20-2015, 06:42 PM | #12 |
Photographer
412
Rep 2,643
Run 40/45 in mine. Should all be somewhere around 40.
Realistically the small tyre size changes won't effect the pressure at all, especially as pressure isn't a measure of volume. 40PSI is always 40PSI no matter what tyre/wheel combination. |
