Slow puncture - is it to close to the sidewall
08-17-2015, 10:27 AM | #1 |
26
Rep 315
Looks like previous repair plug has started to leak slowly. My question is. Is it to close to the sidewall for a normal puncture reair?
2010 E92 Msport lci
08-17-2015, 10:41 AM | #2 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Probably too close for a normal plug - but don't be put off. Ask your tyre place to send it away for a vulcanized repair. They rarely offer this because they want to say 'irreparable - buy a new tyre'.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
08-17-2015, 01:15 PM | #3 |
283
Rep 2,796
To close for sure IMO we certainly wouldn't entertain it, if it's a run flat tyre shouldn't if been repaired(technically)in the first place, also notice which is typical of the breed sadly that the inner tread is scrubbed and also you've feathered the inner edge of the tyre as well, I can see a ridge on the tread block inner edge(step)that again isn't unusual.
08-17-2015, 01:44 PM | #4 |
65
Rep 1,377
Drives: M235i
Would you feel safe with that tyre repaired?
08-18-2015, 10:01 AM | #5 | |
26
Rep 315
2010 E92 Msport lci
08-18-2015, 10:12 AM | #6 |
616
Rep 3,194
4-wheel laser alignment.
08-18-2015, 10:30 AM | #7 |
175
Rep 1,596
