Wing Mirror Gremlins
08-15-2015, 02:09 AM | #1 |
Rep 115
This is really starting to bug me now.....Near enough every time i get in the car (08 e92) the o/s wing mirror is in a different position. to make things more confusing, it doesn't move itself to that same position, some times its up facing the sky other times its right down.
Anyone had this before, and more to the point have a solution? |
08-15-2015, 02:33 AM | #2 |
13347
Rep 7,484
I had lost settings on mine a few months back when the dealership returned it to me. They had used the BC stalk to set day time lights as permanently on. The tech swears they touched no other options but I found that the return to previous user settings upon unlock had been activated. I read through the manual to disable these settings. My only guess is that they may allowed the battery to run low. The spare key had some settings from the previous owner too that I had to adjust - discovered these last year when I gave the spare key to tech at MOT time.
08-15-2015, 03:16 AM | #3 |
840
Rep 1,993
Drives: F30 335d
I take it you have power folding mirrors?
My offside wing mirror does the same, generally it tends to point to the floor but can sometimes point inwards. It only does it when I take the key out or open the door though. It could be a bug in the software? The nearside mirror is flawless though.
if I've helped - an Appreciate would be, er, very appreciated!
08-15-2015, 04:12 AM | #4 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
08-17-2015, 07:23 AM | #5 | |
160
Rep 2,399
take the glass off and take the wiring off and pull the motor out and clean the pins, it takes about 5 minutes each side. it fixed my problem. |
08-20-2015, 02:24 AM | #7 |
840
Rep 1,993
Drives: F30 335d
If you try the phantom mirror fix can you let me know if it works please?
I'd like to do the same but currently sorting out exhaust gremlins
