Random squeaking while driving around?
08-14-2015, 12:14 PM | #1 |
30
Rep 64
Drives: 09 E92 335i
Sometimes, when driving around at low speeds, I hear squeaking noises coming from the left side of the car. Not sure what exactly is causing it. I hear it when I'm just rolling along at low speed without brakes, so I don't think its the brakes.
Any ideas what it could be? Not sure if I should have it looked at or not. Its annoying, sure, but unless its actually causing damage I don't really care. Would appreciate advice! Thanks! |
08-14-2015, 12:44 PM | #4 | |
47
Rep 128
I've read that it has something to do with the wear sensors on the brakes or something that may have to do with the pads still making contact even when released. It's annoying as hell but I haven't had the chance to look in to it much yet. I'm kind of just waiting until it's time to do a brake change to address it, but hopefully someone can provide some insight. |
08-14-2015, 12:44 PM | #5 |
30
Rep 64
Drives: 09 E92 335i
08-14-2015, 12:45 PM | #6 | |
30
Rep 64
Drives: 09 E92 335i
08-14-2015, 12:47 PM | #7 |
36
Rep 191
I had a similar issue, was like a high frequency squeal/squeak noise and only at low speeds. Dealership fixed it by replacing one of the brake sensors. The shop foreman says it's pretty common, may be what you're experiencing.
08-14-2015, 12:59 PM | #8 |
30
Rep 64
Drives: 09 E92 335i
If it is the brake sensor, does squeaking indicate that its faulty? I realize that the brake sensors are a safety component (they let you know if your brakes are fucked), so I want to make sure thats replaced if they're not working.
08-14-2015, 01:52 PM | #9 |
77
Rep 334
Same issue here. Can't tell which side it's coming from, definitely the front though. Happened when I first bought the car and then it went away and actually last night it came back super loud. Like embarrassingly loud as I was coasting through a parking lot.
08-14-2015, 02:12 PM | #10 | ||||
44
Rep 385
I've come to the conclusion is that, OEM brakes produce a lot of dusts, which in turn, causes this squeaks. Now, if you guys are not on OEM parts and have this squeak, then I have no idea hahaha |
08-14-2015, 05:12 PM | #11 | |
30
Rep 64
Drives: 09 E92 335i
08-14-2015, 06:16 PM | #12 | ||
44
Rep 385
